hussainm
oh really? It looks like they do. Thats pretty cool! I really like how they look!No angel eyes here either.
Just to clarify you're running a 55W H1 bulb? About what did you pay for both?The 35w slim ballasts that Jeff sent out with the H1 kits are pretty good, but stacked up to my Bug OEM HID are just lacking. It's not Jeff's fault since we are not dealing with an OEM quality HID setup here. However, compared to the e-code jetta lights, the HIDs are hands down better. Conversing with Jeff on the subject of getting close to my Bug's light output, he suggested I look at the DDM tuning website for the 55w slim ballast for the H1 bulb. Just got them in today. WOW, I've got light! So if you want a whiter white and a brighter light, check out the 55w slim ballast from DDM. Now, these are NOT the same as some 55w ballast found on flea bay which are nothing more that rebadged 35w ballasts (ask me how I know).
I have indeed read about that problem, which is part of the reason why I opted to stick with the 35w ballasts.Just wanted to pop in here and mention that the generic Mini H1 projectors end up with burnt reflector bowls with 55w setups, it doesn't take too long either..
Also, you guys will end up with far better output if you adjust the bulbs in the holder - the pics I've seen have hot spots all over the place. You want the hot spot of the bulb to sit right in the step of the cutoff.
If you intend to use the fog light projectors for DRLs with LED bulbs, then I would recommend removing the cutoff shield from the projector. You'll get more light out of the fixture without the shield.what watt/lumen is the fog you're running? i am getting 3w LEDs to run in mine but will be using them for city/DRL.
they look good.They are 55w PIAA Ion Crystal selective yellow
i will check that out, thanks. i didnt even know there was one.If you intend to use the fog light projectors for DRLs with LED bulbs, then I would recommend removing the cutoff shield from the projector. You'll get more light out of the fixture without the shield.
Can you elaborate a bit on this. I am brand new to these lights and have no idea how to adjust them properly.Just wanted to pop in here and mention that the generic Mini H1 projectors end up with burnt reflector bowls with 55w setups, it doesn't take too long either..
