ninedee_golf_tdi
ra thump ra thump from ip, rough idle, iq fluctuating
A customers very clean, 97,xxx mile, 2002 jetta tdi on which I changed the tb last week, and today new nozzles. I had never heard the car run until after the tb. Now, at idle an intermittent rough idle combined with a cyclical ra thump ra thump kind of noise seeming to come from the ip, combined with the iq going spaz on vag-com happens simultaneously. When it runs poorly, iq fluctuates from a reasonably steady and normal 3.6-3.8 to 3.0-4.8, but timing never changes, rpm fluctuates from 903 down to 885'ish. Strange, yes. Stranger yet is when you depress the clutch pedal, the engine normals out immediately. Keep the clutch depressed, the intermittent rough idle never occurs. Timing is perfect of course, and I checked the pressure relief valve. No smoke ever, the car runs fine otherwise. Something to do with the crank shaft walking maybe ? Debris on the crank position sensor ? Full moon ? Any ideas on this one ? Thanks.
