Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old June 12th, 2019, 15:34   #1
forrest resto`s
Default torque specs..clutch assembly.trans bolts etc
Did a search and just can't find the info?...Anybody have a link or info to where I can get the bolt and nut torque specs on a jetta mk6... trans mounting.. clutch,, and slave/bearing..all associated with pulling the trans ( replace clutch, Throw out/slave bearing, axles etc..) and reinstalling? thanx!... Forrest
forrest resto`s is offline   Reply With Quote
Old June 13th, 2019, 09:56   #2
w123houston
here's what i got...
w123houston is offline   Reply With Quote
torque specs ALH cam cap bolts jimmy0000 TDI 101 7 January 17th, 2014 23:14
ALH injection pump bolts? Torque to Yield? Torque Specs? marshalldanielp TDI 101 1 November 19th, 2012 09:59
torque specs...g60 flywheel bolts orion2.0 TDI 101 2 February 28th, 2008 08:05
Torque specs for the new style (non-stretch) bolts for the injection pump. AbsoluteNovice VW MKIV-A4 TDIs (VE and PD) 1 August 12th, 2006 19:24
Injection Timing Torque Specs for new bolts? Mahoutsukai VW MKIV-A4 TDIs (VE and PD) 2 November 11th, 2004 15:14
Page generated in 0.15406 seconds with 13 queries
[Output: 52.79 Kb. compressed to 48.64 Kb. by saving 4.15 Kb. (7.86%)]
