Old June 12th, 2019, 07:28   #1
Bikoman
Default Could a Flashzilla, flash a pre-fix tune back?
To the guru's out there. If I were to purchase a Flashzilla from Malone, would I be able to a. find a pre fix tune and b. flash it to my 2012 JSW?
Bikoman is offline   Reply With Quote
Old June 12th, 2019, 08:21   #2
calimustang
That would be nice to know.
2011 JSW TDI retired and buyback w almost 300k miles.
2015 Passat TDI DSG
2014 JSW TDI DSG
1989 Mustang GT and 89 Ocala FL SSP coupe 5.0 5MT
calimustang is offline   Reply With Quote
Old June 12th, 2019, 14:28   #3
Owain@malonetuning
no it cannot. The device works off of a stock file, it cannot write a stock file over another stock file (or another vehicle), since they would be different base files or VINs.
Owain@malonetuning is offline   Reply With Quote
Old June 12th, 2019, 15:32   #4
IXLR8
If you had a pre-fix file from your own car, had your car "fixed", you couldn't put the pre-fix file back in the same car post "fix". Is that correct?
Jim Peck
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 298K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear. Failed safety inspect for rust
IXLR8 is offline   Reply With Quote
Old June 13th, 2019, 21:02   #5
ewdysar
According to the Malone website, the Flashzilla v3 will hold just 1 stock tune file and 5 mod tune files. I guess that the trick would be to get a pre-fix stock file marked as a mod file. That would give you your post-fix tune as "stock" and a pre-fix tune as one mod along with whatever other real mod tunes that you have purchased. I think that I read somewhere that most of the tuners use the pre-fix tune as their "base" file, so they might have one available for purchase, for off-road use only, of course...
ewdysar is offline   Reply With Quote
Old June 13th, 2019, 21:14   #6
HPsenicka
Feels like some confusion here....
If you buy a Flashzilla, and use it as intended, you capture the existing ECU file, and store it as the stock tune.
This file can be modified by your tuner, and uploaded to the ECU. If you want to revert back to the original, you can do so at any time by using the Flashzilla to re-upload the stock ECU file that you initially saved.
All of these are locked to a specific vehicle using the VIN, and cannot be swapped between vehicles.
HPsenicka is offline   Reply With Quote
Old June 13th, 2019, 21:48   #7
ewdysar
which is what I was saying. the OP's post-fix stock tune that is in his ECU today would be saved as his stock tune. If he bought a pre-fix stock tune as a mod file (or if the tuner modified his post-fix tune back to stock pre-fix specs), he could upload that pre-fix tune to his ECU under his VIN as a mod. Later, he could revert back to his post-fix stock tune by re-uploading his post-fix tune file that was saved as his stock tune. All one vehicle, one VIN.
Old June 14th, 2019, 11:48   #8
ewdysar
i have to apologize.
First off, I did not notice that one of the replies was from Owain at Malone. Since they are the FlashZilla vendor, his reply should be considered to be straight from the source.
Second, my answers have been merely speculation, I have no direct experience with the product (yet). I was just brainstorming on how the original request might be done, though I personally don’t see much reason why. If I were to go to the trouble and expense of getting an alternate tune, I would opt for the better performance of a stage 1 or stage 2 tune, rather than the almost imperceptible difference between pre-fix and post-fix stock tunes.
Stage 1 Malone tune with Flashzilla loganbingham Private TDI Items for Sale/Wanted 3 April 30th, 2018 05:02
What happens if we took pre-fix payment and don't fix the car due to poor performance Dr Chill Dieselgate - VW Group Emission Scandal 7 December 11th, 2017 17:05
Gen 2 software fix, would ECU tune revert back to old software? Burnt Dieselgate - VW Group Emission Scandal 6 April 25th, 2017 05:54
WTS Malone flashzilla- never used to flash crashmanS Private TDI Items for Sale/Wanted 3 February 14th, 2014 15:53
Can I flash two cars with one Flashzilla? Hear me out. TDI Convert TDI 101 2 October 17th, 2013 16:14
Page generated in 0.16054 seconds with 13 queries
[Output: 84.33 Kb. compressed to 72.70 Kb. by saving 11.63 Kb. (13.79%)]
