Old June 12th, 2019, 11:54   #31
whizznbyu
Fuel Economy: 56 MPG at 60. 51 mpg at 75
Originally Posted by oilhammer View Post
Customer upgraded to a bigger one
What does a bigger turbo do for a B5 if that is all you do? Improve boost? Any change in turbo lag? Better economy? Some threads have shown owners putting in bigger injectors with chipping and bigger turbos, bigger intercooler. Slippery slope here.
whizznbyu is offline   Reply With Quote
Old June 12th, 2019, 12:24   #32
oilhammer's Avatar
Fuel Economy: fantastic
It isn't all you do. Software changes get made to make use of it.
www.cardocautomotive.com
Old June 12th, 2019, 12:41   #33
imo000
imo000's Avatar
Fuel Economy: Good enough
Originally Posted by BBB129 View Post
I think you misunderstood/I wasn't clear, when I say pinched, what i mean is that the pinch caused two 1" gashes in the charge pipe, IM a motocross guy and tubes "pinch" often enough...... not that it was "kinked" and yeah I only put a tiny bit of air through it, like 40 psi through an air nozzle at 12" away, I also pre oiled it before installing, as I didn't want a dry start of course.
I imagine it was the two large holes in my charge pipe that eventually cost me the turbo no? I don't think i've ran her low on oil...one time near the end of an oil change interval it was pretty low on the dipstick tho, need to watch that for sure.....tubro is in but after two weeks she did NOT want to start, looks like ill be doing that fuel prime whatever its called gasket soon...no leaks to the ground from it yet..THANKS AGAIN GUYS!
Charge pipe = pipe after the turbo and before the engine. If you had a leak here, how would this cause the turbo to fail?
imo000 is offline   Reply With Quote
Old June 12th, 2019, 13:30   #34
PickleRick
PickleRick's Avatar
In theory over spool. The idea is a full charged charge pipe creates enough drag there it keeps the turbo from spinning too fast.
Back in my honda tuner car days guys would slap on their turbo and run them to the tuner without a charge pipe. I've heard more than one tuner insist this not be done for fear of ruining a turbo
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old June 12th, 2019, 13:35   #35
oilhammer's Avatar
Except the TDI is smarter... as soon as it detects a loss of boost, it stops trying, and goes into limp mode.
Old June 12th, 2019, 13:37   #36
BBB129
Fuel Economy: Average 45 mpg, often pull a light trailer best tank 52 worst tank low 30's Towing
Ahhhh, I see, I simply do not know what im talking about haha, I assumed it was sucking in through the turbo but that wouldn't make sense, it'd be pushing, so starving for oil must have done the work. should I be worried about my cam, My first oil change on the car was the one I didn't pay attention to as far as oil consumption.....thanks for edumicating me
BBB129 is offline   Reply With Quote
Old June 12th, 2019, 13:40   #37
BBB129
but only if its completely detached and not with a couple holes in the pipe i suppose? I know so little haha
Old June 12th, 2019, 19:41   #38
QuickTD
"Limp mode" will protect the turbo but running the compressor into free air will protect it even more. The more air a centrifugal compressor moves, the more power it requires. Running into an open pipe or a severe leak will slow the compressor much more than running into the engine.
A good practical example of this is a vacuum cleaner. Choke the inlet and it revs out, you are reducing airflow which reduces the load on the motor.
QuickTD is offline   Reply With Quote
Old June 13th, 2019, 05:19   #39
whizznbyu
Customer upgraded to a bigger one, this one had about 120k miles on it and was working OK when I took it off.
What does a bigger turbo do for overall performance/fuel economy. Is it a plug and play deal or do the injectors, intercooler, etc, and chip need to be modified?
Old June 13th, 2019, 05:27   #40
oilhammer's Avatar
^^^this^^^
I personally would not bother with it, because the BHW with a simple modest software change makes plenty more power for me, even stock is actually pretty good. And, like the ALH, the BHW got a Garrett turbocharger from the factory already, so they are pretty durable to begin with.
But if you want more than that, and some people do, then a larger turbo will allow more airflow. The stock injectors already have a reasonable amount of surplus fueling capabilities.
I am not really sure I understand the nature of your repeated question. Certainly someone who has been a member of the TDI club since 2006 has gained some knowledge of power mods and turbochargers? Pretty common knowledge here. The stock turbochargers on ALL the TDIs are pretty tiny.
Old June 17th, 2019, 10:16   #41
whizznbyu
^^^this^^^
I do not recall asking this question, and if I did I do not remember what the answer was. Sorry.
Old June 17th, 2019, 13:45   #42
oilhammer's Avatar
Post #31 and post #39 is what I was referring to. Sorry, didn't mean to confuse anything.
Old June 19th, 2019, 16:00   #43
whizznbyu
sorry about that. I was trying to get an answer along the lines of what things are done to make use of a bigger turbo. Intercoolers, what remapping needs to be done, what size injectors etc. And, if any of the modifications can allow the driver to maintain great fuel economy but have available power on demand.
Old June 20th, 2019, 08:39   #44
zzdiesel
My FNH conversion and stage two tune gives me all the power I need or want and does 42 MPG on highway regularly.
zzdiesel is offline   Reply With Quote
Old June 20th, 2019, 14:06   #45
PickleRick
PickleRick's Avatar
Even on my stage 2 tuned BHW mated to a DVZ i get approximately 41 to 43 mph. I set cruise on 3000 rpms which is approx 75 mph.
Turbo upgrade for 2005 passat tdi bhw 1bdtdi VW B5 Passat TDIs 13 November 13th, 2014 04:42
Garrett B5.5 BHW TDI VNT17 Turbo ('04-05) dh13 Private TDI Items for Sale/Wanted 12 October 28th, 2012 08:29
Transmission Pan Damage for '05 Passat TDI BHW TheApprentice VW B5 Passat TDIs 3 October 3rd, 2011 04:41
BHW Oil Filter Location '05 Passat TDI passat77445 VW B5 Passat TDIs 9 March 8th, 2009 13:09
04-05 Passat TDI BHW Motor for sale texascadillac42 Private TDI Items for Sale/Wanted 0 February 9th, 2009 17:48
Page generated in 0.18287 seconds with 13 queries
[Output: 130.82 Kb. compressed to 109.38 Kb. by saving 21.44 Kb. (16.39%)]
