Old June 9th, 2019, 15:42   #16
beckster
So interestingly enough, we got the turbo out this afternoon and the impellers seem to be in ok condition and don't have any play. Considering the turbo has about 200k on it, it's probably not a bad idea to rebuild it at this point. Is there something else we could be missing that would cause oil to come out the tailpipe and go into the intercooler? Maybe just the seals blew out? Thoughts?
2003 Golf GLS TDI - 235k mi - stock
2003 Jetta GLS TDI - 296k mi - not stock
beckster is offline   Reply With Quote
Old June 9th, 2019, 16:02   #17
Yourbuddysatin
Fuel Economy: 32-35mpg
Probably bad seal
Yourbuddysatin is offline   Reply With Quote
Old June 9th, 2019, 16:52   #18
No seals in a VNT-17. The impeller floats on a cushion of oil, and equal pressure on both sides of the center of the shaft keep the oil flowing through the turbo. When the turbo loses pressure on one side it'll push oil to the low pressure side. In this case it sounds like that's the turbine (hot) side, which is why oil came out the tailpipe. If the shaft isn't broken you may have galling of the shaft from oil contamination.
2002 Jetta wagon, 407K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old June 9th, 2019, 18:26   #19
Yourbuddysatin
Ahhh that’s good to know indigo!
Old June 12th, 2019, 11:38   #20
VWdrummer
Fuel Economy: 40-41 measured with Fuelly
Originally Posted by KERMA View Post
Gratz on 200k miles of service out of a "lowly" VNT17. Now build it better stronger faster than before. 17 plus
please contact info@kermatdi.com or 877-537-6283 and mention your personal details and this thread.
I second this, the S7 turbo they sell is excellent too. Previously, I ran a vnt17 and am now running an S7 and I couldn't be happier.
2002 Jetta: Bosio DLC 1019 nozzles, 4 speed auto to (DRW) 6-speed manual conversion, 20th-anniversary GTI big brake kit, BW S7 turbo (Kerma), Darkside Developments Intake Manifold, APR FMIC, KERMA TDI tune, 3" Turbo back exhaust
VWdrummer is offline   Reply With Quote
Old June 21st, 2019, 15:21   #21
jeff@tdiecutuning
Fuel Economy: 5l/100
if you are looking for another turbo check out xman turbo im not sure if he is a vendor on here or not tho
jeff@tdiecutuning is offline   Reply With Quote
Old June 21st, 2019, 21:42   #22
Typrus
There's pretty clearly oil on both sides.
I've yet to see a turbo without seals. Most use a simple steel ring seal as a rubber seal wouldn't live at the temperatures and speeds they would be exposed to. Some use 2 ring seals, staggered as you would see on a piston.
I must ask, is your crankcase vent flowing properly and oil return unrestricted? You may have had a failure in the turbo that caused simultaneous seal failure but it is unlikely if the shaft is intact, spins freely, and has acceptable play.
High crankcase pressure and poor oil return can cause simultaneous seal failure, it would be wise to rule out both possibilities if you can.
1996 VW Passat TDI Sedan 5mt-- Sold @ 300k+
2002 Jetta Sedan GLS/TDI 5mt -- 112k+
Typrus is offline   Reply With Quote
Old June 22nd, 2019, 18:40   #23
Mongler98
Lack of shaft play does not mean that the turbo is still good. 99.9% of the failure with oil like this is from the journal bearing not holding the oil back, some makes it past but most of it like 98.9% of the oil goes to the return. When the journal bearing gets too hot from excess EGT's , heat soaking oil cooking after shut off, the return gets more resistance and the bearing is worn a bit causing excess oil pressure and it seeks the path of least resistance and that sir is your IC pipes. Now when the journal bearings decides to let go for whatever reason, oil will go EVERYWHERE, not just out of the exhaust it will go out the intake and out of the output of the turbo. There are moments of back pressure where oil vapor will make it to the air filter and MAF from the CCV on worn down older TDI's Not sure why but every TDI i have ever worked on or seen all have the same thing, oil mist on the air filter and on the MAF,
SO having oil on the input of the turbo means nothing good but not necessarily bad.
Point is, 200K is NOTHING in TDI miles and your turbo might still be ok.
Oil can comes from CCV, and i mean LOTS of oil if you have excessive blow by and higher than usual RPMS.
Rebuilding the VTN is cheap and i would have that done IIWY
Leakdown test, cold and HOT same with compression test is in your future once it runs again.
Old July 4th, 2019, 07:11   #24
beckster
so update, and not a good one.
We worked with Mike at Kerma, he was great. Got us a turbo and then we ended up needing the intercooler adapter part. Great guy, fast shipping both times. Got the turbo installed and we still have white/blusish smoke and oil coming from the exhaust.
We did prelube the turbo by disconnecting the injection pump harness and cranking the engine with only the turbo feed line installed and saw oil coming from the oil return port. I took off looked at the oil return line and it was fine, can see all the way through it. re used the old return line and installed a new stainless steel braided oil feed line.
we ran it and it boosted good and held the boost. at first we though maybe there was some oil still left in the exhaust from the other turbo. i took off the down pipe and saw oil in there. there was a little dripping from where the downpipe and turbo meet. took off the intercooler side and saw a little oil in there like a small amount. upper intercooler pipes are slightly oily going into intake manifold.
at a loss as to why theres still oil getting into the exhaust side of the turbo.
any ideas?
Old July 4th, 2019, 09:25   #25
[486]
TDI(s): 02 golf ALH
Originally Posted by beckster View Post
any ideas?
Mishimoto catch can
pics of loop
needs to go back into the intake, post MAF or you'll be breathing backwards no matter what you do as the compressor housing is under negative pressure when not under boost and the crankcase will always be under some pressure from normal blowby
also, guys that run catch cans always seem to run little tiny fittings and hoses where you need something that's 5/8" ID through every port to even match stock CCV flow
also, oil drain hose can fail internally where it blocks flow. cut the ferrules off, toss the old hose and stretch some 1/2" transmission cooler hose over the barbs
[486] is online now   Reply With Quote
Old July 4th, 2019, 09:55   #26
How much have you driven it with the new turbo? Depending on how the old one failed it can take a LONG time to get rid of oil in the system. If it's running properly I'd go drive it 50-100 miles at highway speeds and see if you burn the oil off. And of course watch the dipstick, and be prepared for a runaway if a lot of oil in the intercooler system gets funneled into the engine. See if it clears up.
Old July 5th, 2019, 19:40   #27
beckster
prob taking a break from the car.
the catch can, theres a hose coming from the valve cover into the "in" port of the catch can, then the "out" goes back into the bottom of the intake tube, right next to the air filter box. hoses are decent sized. didnt actually measure but it does seem to be around 5/8ths.
we have only driven less than 5 miles with new turbo. we installed a diesel geek skid plate, which is now interfering with one if the pipes of the front mount kit that came on the car so we have to order a longer coupler to make it work.
also looking into figuring out the smoking issue. any ideas on how to test the injectors/nozzles and the cam to see if theyre fine or not?
Old July 6th, 2019, 02:52   #28
Tdijarhead
Drive it, if you had oil coming out your exhaust then your exhaust is full of oil. After I put mine back together I had to drive it a full 10-12 miles to burn all the oil out of the exhaust. I stopped three times during the drive to check my oil and make sure I wasn’t loosing any.
If you live in a highly populated area it should be great fun because you will leave a trail of smoke that will be very impressive and repel mosquitoes for at least a week. Your neighbors will thank you.
Old December 22nd, 2019, 18:47   #29
Redrocketdi
Any update?
Sent from my SM-N960U using Tapatalk
Redrocketdi is offline   Reply With Quote
WTB: vnt 17/22 vnt 17/52 17/56 or vnt 17 Srb88042 Private TDI Items for Sale/Wanted 1 November 18th, 2016 18:05
DPF bit the dust !!!! Softrockrenegade VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 181 June 9th, 2015 15:29
VNT 17/22 Smokes a bit Much Acceletaing TDITransporter TDI 101 3 June 9th, 2015 02:37
Another Transmission Bit the Dust 1854sailor VW B5 Passat TDIs 15 March 13th, 2014 11:08
01slvrTDi's TDI bit the dust Windowlicker West Coast Canada/USA 34 December 5th, 2007 17:04
Page generated in 0.19703 seconds with 14 queries
[Output: 123.16 Kb. compressed to 103.84 Kb. by saving 19.33 Kb. (15.69%)]
