Old February 13th, 2020, 19:56   #1
pkhoury
That guy with the goats
pkhoury's Avatar
Default Problems shifting into third - 02Q
If I'm shifting somewhat quickly, or I shift when I'm revved relatively high in second, I have problems getting the shifter into gear. Someone told me it could be the transmission or my gear oil, but I'm not too sure, as this happened on two different transmissions (I swapped transmissions, because I installed a stronger clutch and a Peloquin LSD, and I used a spare 02Q to accomplish the LSD portion).
I know I should take any advice from the facebook group with a grain of salt (or half a grain), but several suggested something like this. Wanted to see if anyone else has done this or not.
I noticed also the problem is more prevalent when the car/engine compartment is cold.
first link
second linkl
The only other thing I can think of is stainless shifter forks, but I would only notice that if I broke the brass riveted fork, right?
2013 JSW 02Q - Malone Stage 3, CR170, rawtek 3" straight pipe, PolarFIS, Panzer plate, front fogs, Bosal towhitch, Neuspeed 28mm swaybar, Sachs racing clutch, Peloquin LSD, dieselgeek shortshifter
2004 Golf GLS 02J - Malone Stage 4, VNT17, DC Stage 2 clutch, darkside 2.5" downpipe, MFA cluster swap
2003 Jetta GLS 01M - totally stock, used on the ranch only; future Ute conversion
pkhoury is offline   Reply With Quote
Old February 14th, 2020, 18:34   #2
Racerman27410
did you by chance install a single mass flywheel when you did the clutch? I found out the hard way that the 3rd gear synchro is a weak point in this transmission and does NOT like a single mass flywheel.
Racerman27410 is offline   Reply With Quote
Old February 14th, 2020, 22:44   #3
pkhoury
pkhoury's Avatar
HELL NO. I used a Sachs DMF racing clutch from darkside developments. I did my research and decided I wouldn't do the SMF route on the 02Q, and only darkside had the clutch I wanted, at the price I wanted (it's good for 409 lb ft).
shifting problems bonyai TDI 101 2 October 6th, 2015 11:50
Intermittent (but very frequent) problems engaging / disengaging reverse / 1st 02Q wega3k VW MKV-A5 Golf/Jettas 1 July 2nd, 2012 14:49
Serious shifting problems jeffinstereo VW MKIII-A3/B4 TDIs 6 May 11th, 2011 16:50
Problems shifting.....Please help. AZ98TDI VW MKIII-A3/B4 TDIs 5 October 8th, 2010 20:36
Shifting Problems petersonpr TDI 101 24 October 26th, 2009 12:15
Page generated in 0.14555 seconds with 13 queries
[Output: 60.08 Kb. compressed to 54.50 Kb. by saving 5.58 Kb. (9.28%)]
