Dirty_Al
I bought a 2002 Audi Allroad with a great body and nice interior with 142K miles on it. My goal is to put an 1.9L TDI ALH engine into it. The plan is to buy a parts car with a 1.9L ALH and strip the engine, ecu, harness, turbo, etc... to put into the Allroad.
The 6 speed manual should bolt directly to the engine no problem, just need to make some engine mounts and get a lower profile oil pan out of Europe.
The plan is to get it running to make sure there aren't any major issues before getting to invested.
Once running, pull the engine, rebuild it. Rebuild the transmissions with some taller gears that will play nice with the TDI and put a new Turbo, Injectors and Tune on the engine so that it will pull the 4K lbs of Allroad around nicely.
Should be a practically new drivetrain on a really nice body that gets ~35 mpg that can off-road and pull a small trailer no problem for around $10K that has cheap insurance & registration rates!
Feel free to add advice, but please don't use this as your soapbox...Thank you!
I will add pics and updates as we go through the process...
Huge thanks to Bryan at Tullin Concepts / audis4parts.com for making this project a reality!
