Bopper
Right rear window stopped half way up, clunked, then stayed where it was. It did then go down via power. I can now hear the window motor running when I press the switch with no window movement.
I took the interior off and was able to manually push the window upwards while wife would hold the power switch towards up.
I searched the forums and found that regulator and clips are commonly mentioned. I need more help please.
