Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old June 4th, 2019, 22:28   #1
Adrian rushforth
Default 04 golf tdi sensor?
Can anyone tell me what this is on the ccv breather tube, is it a sensor?
Sent from my SM-G965W using Tapatalk
Adrian rushforth is offline   Reply With Quote
Old June 5th, 2019, 05:17   #2
CopaMundial
CCV Heater
https://www.idparts.com/ccv-heater-a4-p-7472.html
Welcome to the TDIClub forum. If this community forum helped you save money on a purchase or repairs, please consider donating just a small percentage of what you saved using the 'donate' link HERE. Donations keep the forum going. (note: I'm not affiliated with TDIClub or Fred... I just can't imagine the world without either of them)
CopaMundial is offline   Reply With Quote
Old June 5th, 2019, 05:53   #3
Adrian rushforth
Thanks what is the purpose of this heater?
Old June 5th, 2019, 16:45   #4
CopaMundial
Water vapor condenses out of the crankcase fumes. The heater prevents that from freezing and blocking the small breather hose.
Old June 5th, 2019, 18:00   #5
Adrian rushforth
Ok that makes sense thanks for response
04 Jetta wagon GL parts to 04 Golf GLS coalminer16 VW MKIV-A4 TDIs (VE and PD) 3 January 29th, 2016 15:24
04 Golf right hatch harness PN 1J69711726N - where to get/craash sensor side airbag coalminer16 VW MKIV-A4 TDIs (VE and PD) 3 March 23rd, 2015 14:15
O2 Sensor questions 04 TDI frankrey1 TDI 101 5 December 11th, 2011 07:17
Coolant Temp Sensor Fault Question 04 Golf OlyTDI TDI 101 8 November 13th, 2011 18:44
'04 Golf & '04 Jetta Noise Difference Initnow VW MKIV-A4 TDIs (VE and PD) 1 June 30th, 2004 10:58
Page generated in 0.13626 seconds with 11 queries
[Output: 67.30 Kb. compressed to 59.58 Kb. by saving 7.72 Kb. (11.47%)]
