My bulb indicator light came on with the rear right signal bulb out message, it looked fine, but I changed it anyway, started the car again and the warning came back on so i had a look, the light was working just fine.
I did a complete walk around with the hazards on, then just left signal, right signal, reverse, brake, headlights on and off and every single bulb is working just fine, but the bulb indicator light is on AND the right signal indicator is flashing super fast.
Please don't answer with a thought or opinion, just looking to find some who who has had this problem and what they did to fix it.. yes i could check the Central Electronics Control Module, grounds, trace the wires etc, but i'd rather just find someone who has had this issue and what they did to fix it.
Thank you in advance cause I know you are out there
