trbonium
Hi everyone,
Is there any way to prolong the life of the turbos on these cars and if so, do I have to go DPF delete or make sure the car doesn't shut down during regen, keeping the bearings too hot in the turbo?
Has anyone gone turbo timer despite all the hype these days about not needing one?
DETAILS:
_
2010 Golf TDI 6spd Manual, all stock, no drivetrain or engine mods
Religious Oil changes every 5k with Penzoil, Lubri Moly, Mobil1, or Castrol
_
WHAT HAPPENED?
Driving Home under part load (actually headed downhill but on the gas) felt a sudden drop in power. Then heard a whining/light grinding sound coming from the engine, kind of like a supercharger whine actually.
If you listen closely to this video, you can hear the whining/grinding sound over the clickety clack of the TDI engine...
_
https://youtu.be/ZZ9Y2buEPdI
_
Code P0299 was found after I got the car home.
Was able to drive home but with significantly reduced power.
Started car again a couple times to move it and verify sound coming from turbo area. Upon removal of the PS side (right side of the car) intercooler hose, found black oil that leaked out making approx 6 inch puddle on floor. No oil came out of Driver's Side Intercooler hose.
Removed engine out the front. Took about 5 hours with a lift and the engine hoist/cherry picker. Not bad considering I also have to do the timing belt now that I'm signed up for a $1000 turbo replacement cost just in parts.
Yanked off the DPF(?) and then turbo (took another hour). Found that the compressor side of the turbo (clean air side) was wobbling slightly per this video...
_
https://youtu.be/ipD8rTF16cs
I've not yet ordered a DPF delete kit but I ordered a new factory replacement turbo and install kit from Europa parts. BTW emissions not req'd where I live.
_
Thanks all!
<BR>
_
<BR>
<BR>
<BR>
<BR>
DETAILS:
_
_
WHAT HAPPENED?
_
_
_
_
Thanks all!
<BR>
_
<BR>
<BR>
<BR>
<BR>
