Old June 14th, 2019, 00:49   #1
bmc1980
Default part number - cap by door handle
Does anyone know this part number? If you're looking right at the door handle (esp. the rear door handle) on a 2014 JSW with convenience opening (no keyholes), it is that small cap piece to the right (or left depending on the side of the car you're on) that finishes the door handle (if that makes sense). My 2014 JSW is missing the cap on the passenger side rear door. The dealer I bought it from ordered the part, but it was the wrong part number, as the cap had a little dimple in it (from what I can see, that dimple is only on the cap if the car doesn't have the convenience opening feature, meaning the driver's side door has a conventional key hole). I've looked on vwpartscenter.net using my VIN, but I'm not sure its the right part. The dealer that ordered it before using my VIN ordered the wrong piece. Please advise...
*edit to post - the piece that was originally ordered that isn't correct can be seen here:
https://parts.vw.com/p/Volkswagen_20...839879GRU.html
As you can see, the cap piece has a small dimple in it for your thumb. Again, the cap on my 2014 doesn't, yet, when I put in my VIN number, this is the part that comes up.
bmc1980 is offline   Reply With Quote
Old June 14th, 2019, 05:12   #2
oilhammer's Avatar
Fuel Economy: fantastic
Are the parts guys that dumb? Seriously, the only other choice, which is RIGHT NEXT TO THAT PART in ETKA, is:
1K5-837-880-GRU
google THAT part number, see if it looks like what you want. I'll bet it is.
www.cardocautomotive.com
Old June 14th, 2019, 07:31   #3
bmc1980
1K5-837-880-GRU
Sorry, Iím a newbie here - what is ETKA?
I googled that part number, and the only one that came up was on eBay - it does appear to be the correct part, however, when I search it on vwpartscenter.net it doesnít recognize the number.
Itís actually a little confusing, because it says part number 1K5839879GRU fits my vehicle, and it doesnít, because the cap for that part number has the thumb dimple, which I donít want.
Old June 14th, 2019, 07:35   #4
oilhammer's Avatar
Here:
https://www.google.com/search?safe=o...iz.Ez1cdGdMGm8
ETKA is the Volkswagen parts software.
Just spoon feed them the number I gave you, and have them order that.
It will need to be painted to match your car. The 'GRU' suffix means it is in primer. That is short for "grundierung", which is the German word for primer.
Old June 14th, 2019, 20:26   #5
bmc1980
Here:
Thanks for your assistance - I had a VW dealer order the part, and I'll be picking it up tomorrow. Unfortunately, the dealers don't do the painting, but they have body shop partners I could take it too. Given the tiny size of the piece, I'm hoping it is something they could just do for me on the spot, without much waiting. It shouldn't take very long, but you never know...I'm just anxious to get this cap piece on, as having it missing is an eyesore.
anyone know part number for adjuster cable for door handle? lebaronGTC VW MKIV-A4 TDIs (VE and PD) 3 June 9th, 2016 14:46
Part number for center cap retaining ring. pyromancer TDI 101 1 May 27th, 2013 18:48
oil cap or gasket part number help milehighassassin TDI 101 6 March 31st, 2009 20:21
R8 oil cap, need part number eXtenZy Upgrades (non TDI Engine related) 17 August 20th, 2008 13:54
Part number needed, fuel return nipple cap daBooj VW MKIV-A4 TDIs (VE and PD) 2 August 15th, 2006 08:52
Page generated in 0.14738 seconds with 13 queries
[Output: 73.45 Kb. compressed to 65.31 Kb. by saving 8.13 Kb. (11.07%)]
