Dgravle514
I am a relatively new to the TDI world. I made my purchase back in November and now that its warmer weather I am having AC issues. I have read and learned tons from the forum in the last few months. I genuinely appreciate all of your input and time that you guys have put into the library of information.
Symptoms are:
Intermittent Cold Air (mostly cool-warm)
Constant High-ish Engine RPMS = Cooler Air
I took it to AC mechanic and he said it needed complete compressor, condenser, and expansion valve replacement.
He did not mention anything about replacing just the RCV, but after a little research I may give him a call and ask him about replacing it. I may replace it myself and have him drain and fill system.
I have gathered some values from the VCDS. The AC system does not have any active or prior fault codes. Does anybody have an input based on the values posted in below? The car was running at idle speed.
Refrigerant Pressure - 8.6 Bar
Compressor Shut Off Req. - Compressor active
Compressor current -.82A
Compressor Speed- 1000/ Min
Compressor Load- 3.7 NM
Coolant Fan actual- 26.8
Coolant Fan activation- Specified 20.8%
Outside Air Temperature- 28 C
Temperature after evaporator- MUX -25.7
Compressor shut off last- Outside air temp too low
On a side note is the dryer included in the condenser or is it a separate part?
Thanks in advance.
Symptoms are:
Thanks in advance.
