maddmatt21
Hi all,
I've been reading for a bit trying to solve a problem with my 2000 Jetta TDI and could really use a few suggestions. For seemingly no reason, once in awhile the coil light does not light when the key is turned so of course the engine cranks but does not fire. If I leave it and do nothing for a bit (hour, 2 hours, overnight, no telling really) then often it WILL start and will run and start perfectly for months. It never dies when it's actually running.
The difficult thing here of course is that a.) it's tough to diagnose and solve when it's working perfectly and b.) when it fails I don't have my tools or am not in a position to work on it, then when I get it home and I'm ready to go it works fine.
After reading here I first thought it was Relay 109, changed that with no difference made (I actually thought that was it, as it started after I changed it but then it did it again a week later). Checked all the fuses, nothing seems to be amiss. I bought a Ross Tech to help try and figure it out and the only code that appears is:
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 L
Component: A4-KOMBIINSTR. VDO V56
Coding: 07242
Shop #: WSC 00066
VCID: 2B55FB8CD9DD61461E5-5140
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0X1517788
IMMO-IDENTNR: VWZ7Z0X1517788
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
VCID: F0EFACE0B07BC29EEB7-515E
1 Fault Found:
Is the first thing to try basically replacing the ECM with a new one? I'm thinking that it couldn't be the harness, because why would it not work and then 20 minutes later work fine for months without the car moving or any changes made? It's also a bit hard to test the harness, because like I said it won't STAY broken long enough to get things apart and get a meter in there to check voltages.
Any help or suggestions would be great, it's driving me crazy not knowing at any given time if a key turn is going to be successful.
Coding: 07242
Shop #: WSC 00066
1 Fault Found:
Coding: 00006
Shop #: WSC 00066
1 Fault Found:
