jettawreck
Timing jumping around a bit is normal. I like to use the TDI timing check graph feature in VCDS. If you select "cloud" it will average all the targets into one so it's less confusing.
Be sure to select the correct engine family from the drop down menu.
As suspected the CTS was ok and would read near -40F unplugged.
Makes quite a difference when set correctly. It will cold start the best advanced almost to the top of the spec in the graph.
