I would think this will be the opposite effect. With the fuel guard in place the spotlight would be on fuel pump design. But, I would also assume that this will cut failures in half or more. Which may then work against VW finding a real solution as the failures will be so few that it will not warrant a recall or tsb.
Perhaps I didn't explain myself. Here's what I mean:
If an owner refuses to install fuel guard, (say because he worries that he will be stranded in the middle of nowhere on E with the only nozzle available a big rig style or gasoline sized one, something that has happened to me on more than one occasion) and then suffers a HPFP failure, VW will say, "you Mr. Owner must have misfueled it. We have a guard to prevent this from happening, but you refused to install it. That HPFP failure is therefore your fault, Oh and here's your bill for $8,000"
But if an owner does install it and later has a HPFP failure VW will say "Fuel was contaminated with gasoline. It must be the fault of your gas station as we have a guard installed to prevent accidental use of wrong pump. Here's your bill for $8,000, now go sue Shell, BP, Mobil, whoever."
Either way I see "goodwill" HPFP repairs coming to a rapid end.
