SPACE AGE PROTECTION FOR YOUR CAR, TRUCK, BOAT, RV, AIRPLANE & MOTORCYCLE
RejeX is a thin-film polymer coating designed to provide a high-release surface. This very thin film – less than a micron thick – prevents stains and adhesion of common contaminants such as exhaust, bugs, oil, tree sap, bird droppings, road grime, brake dust, etc. It also makes graffiti easy to remove and can be applied to windshields to repel rain. It’s easy to apply and produces a deep, lustrous shine that outlasts the most popular waxes by months.
PROTECTS AND BEAUTIFIES PAINTED METAL, GLASS, ACRYLIC, GEL COAT, FIBERGLASS, GLOSSY PLASTIC & POLISHED METAL SURFACES
RejeX is not meant to be used on porous surfaces, highly oxidized painted surfaces, or to fill fine scratches. RejeX can be applied in multiple coats, allowing 8 hours curing time between coats for deeper color and greater depth of gloss. RejeX has a higher refractive index than waxes, so it produces richer, deeper looking colors and a lustrous long-lasting finish.
RejeX can be used over existing wax; however, the duration of protection will be reduced as the softer underlying wax degrades comparatively quickly. There is no reason to wax over RejeX. As we’ve already said, RejeX leaves a shinier, longer-lasting finish than wax… and the wax can't adhere well to RejeX!
