ToBiN
- Joined
- Feb 9, 2017
- Location
- Colorado
- TDI
- 2013 Sportwagen TDI/M6; 2006 Dodge 3500 Cummins/M6 Mega Cab; 2011 Jetta TDI/M6 (sold)
Ok, posting for a friend until I can convince him to sign on to TDIClub for himself.
He purchased this 2006 TDI Jetta, 1.9L DSG with 115k miles about 5 years ago. It has the sagging headliner that he still has not fixed.
Last year about this time he heard a pop and no power until the oil light came on. He put more oil in it and got it home only to find out the turbo shaft broke. He then ordered a new turbo and exhaust mani and installed them. Was happy to have his car back until 2 weeks ago. It seemed sluggish, no power, and would roll coal until the turbo boosted, at about 3k rpms. Now the car has about 150k miles.
So he took it to a shop that told him he had flat cam lobes. He just paid $2581 to replace the cam and lifters via this shop. Estimate below. Now back to the same/original issue after turbo replacement. No power and black smoke until about 3k rpms.
- Valve cover gasket: $34
- high pressure fuel pump gasket: $19
- camshaft seal: $12
- camshaft: $650
- camshaft follower(lifter bucket): $40 ea. x 8: $320
- camshaft bearing set: $105
- camshaft retainer bolts: $4 ea. x 10: $40
- labor: $1120
Additional costs:
- tax: $100
- shop supplies/hazmat: $41
- initial diagnosis: $140
Approximate total cost: $2581 out the door
My question; is this something that can be caused by the electronic wastegate actuator? Is it possible the new wastegate actuator is bleeding off exhaust causing it to boost later but the computer is expecting boost at 2200-2400 rpm instead of 3k? If so, how can he adjust this? Is there an adjustment or does he need to find a stock actuator and swap them out?
I don't think he still has the old turbo with the original actuator. I think he had to send that in as a core. I should've warned him to swap actuators. I am a terrible friend for this.
I told him that maybe he just needs a tune so it will boost at lower rpms, but if the actuator is actually allowing some exhaust bleed off Im not sure the tune would be able to fight against this issue.
Please send thoughts, comments, suggestions. Has anyone else experienced this issue?
- camshaft: $650
- labor: $1120
Additional costs:
- tax: $100
