MarsBar
- Joined
- Apr 28, 2008
- Location
- San Jose, CA
- TDI
- B4V#2 "Flash", 2000 Jetta GL, B4V#1 "PaTuDI" (2008-2018 RIP)
Life continues to be crazy with too many things all needing attention. With time being at a premium, suggestions on what to check first are much appreciated.
The issue first was intermittent wouldn't start on the first try. Cluster lights come on, GP light cycles, turn the key and may get a short buzz sounding like from the firewall right in front of the driver, and it would either start or nothing. Might take 2-3 tries, wouldn't get the buzz each time, before it would actually crank and fire. May go days between events, may happen multiple times daily for several days. Zero consistency. Finally, whatever it is failed completely and Flash won't start at all. All the lights come on, GP light cycles off, but turn the key the rest of the way and you get bupkus.
When it started failing worse, the old whacking around the starter would get it to turn over. Starter is about 2 years old, the PO replaced it for these symptoms. Even a cheap starter should last longer, I'd think. HOWEVER, hubby (real mechanic) pulled the connector on the end of the solenoid and checked voltage when I turned the key and said it was low but didn't mention a specific number. Haven't had time to go further. The Jetta needs attention, too, so Saturday has been declared "work on the damn cars" day.
Soooooo, the starter could be an effect but not the cause. Ideas of what would result in low voltage to the solenoid? Battery has 13+ volts in it, 6 months old, good quality Group 47. Hoping not the ignition switch, PITA to get to in order to replace, although a lot cheaper than a starter.
In order of probability, what should he focus on checking?
