porsche189
I bought the car with a timing belt broken. How do I verify that the Injection pump when it is pinned is in the right position to fire for Cylinder 1 TDC? Is this an electronic pump or will the pin alone be fine when pulley gets put back on and pin fits?
*I have the head off to get repaired... definate valve piston contact, but nothing broken off
*Crank is at TDC
Any tips? I don't understand the pump side and where it has its markings
*Crank is at TDC
