nikolay_ss
Hello guys,
I have modified ALH with 11mm pump, DE143, Bosio DLC 1019 (0.216um), GT1749VA, 3 bar map sensor, air intake and intake manifold from PD130/150 and some more minor mods.
I use stock N75 map from ASZ and boost target map till 50mg also stock from ASZ, for 60mg-65mg(near 4V pump voltage) I did set it to go at 2400mbar at 2000rpm, 2500mbar at 2250rpm till 3750rpm.
The problem is that in any other gear, but not 5th it goes to like 3000mbar and don't go back if I did not let the gas pedal. If I WOT it at 5th gear it goes for peak of 2700mbar then goes back to 2500mbar and everything is good, but if I do this in 3rd gear it goes to 3000mbar and never come back until I release the gas pedal. Any ideas?
The geometry is clean, and actuator moves free. Not sure if this problem may be caused from N75. Because I have no problems at 5th gear, everything is as it needs to be.
Thanks!
Thanks!
