or 10 minutes of it running and goes thru the self diagnostics.
Only thing that will stick is if you disconnected an Airbag sensor/indicator with the battery installed. I had to disconnect the battery when I installed the back up camera on the '12 Passat, and took off the dash trim/airbag indicator light.
I have a 2013 also and had to replace my battery a couple of weeks ago. All the lights eventually went out but the license plate light intermittently flashes an error. I bought a new bulb but before I could change it, the light works again. Then goes off again and the error returns. Don't see how the battery change and the light malfunction could be related.
It may not be related. I had the same issue with a different bulb. Turns out the filament fractured; made electrical contact most days, but no all. You can tell by flicking the bulb with your finger. If the filament vibrates, it's fractured.
