BatCobra
Good morning from a Newbie. While waiting for my account to become active, I have been reading lots of posts about my problem, so, I know that there have been discussions about my issue, but I would like some confirmation. The problem is likely either a blown head gasket, warped head, or busted oil cooler. To start with, my car is an 03 Golf, TDI 1.9 automatic. This is my son's car and he is 17. I regularly tell him to watch the gauges, and we have dealt with coolant loss, so this is not a new issue for us. The old coolant loss issue was a cracked flange on the drivers side of the engine. When that was happening, my son allowed the engine to overheat while coming home one night.
Fast forward to now. Last Friday, he was driving and saw the Low Coolant light come on. The temp went way over 190, and at some point, he stopped at a gas station and filled up the coolant bottle. Remember I said he is 17 ? Hard to get detailed info from a teenager. When he got home, I looked for the coolant leak and could not find one. The reservoir was empty. I filled it, and after driving a bit, the light came on again and the reservoir was close to empty. Let it sit overnight. In the morning, I looked in the reservoir and there were black spots in the little bit of coolant left. I poured some more coolant in, and the whole thing became an oily soup. Obviously motor oil in the coolant. Pulled the dipstick and the oil was black, not milky. Started the engine and it sounds normal and seems to run fine. I only ran it for about a minute. Having never done a head gasket before, I decided to close the hood and do my research before messing with anything. What I learned on this forum is that the oil cooler could be one of the problems. However, would the oil cooler cause coolant 'loss'?
So, here are my questions: Could it be the oil cooler or is it definitely the head gasket? What are the best tests to determine whether it is the oil cooler or the head gasket before taking the head off? Thanks.
