What makes you think Castrol isn't fully synthetic?
It's not. All Synthetic Castrol is group III oils. Do more research on web.
With all respect don't go there, where "redneck" lives.phifly,
You are correct, this country was settled by immigrants, but please consider this one very important point:
Only ONE person loses out when you post something that no-one can quite understand: YOU are the one that loses. Only you and no-one else.
This has not a damn thing to do with respect of a language or a person or where that person came from.... if you cannot effectively communicate, you are just wasting your time.
If you have a question and we can understand it, we will try to help you.
Bill
Anyone else find it odd that the OEM oil is a group III even though it isn't "true" synthetic and can't be marketed as such in Germany?Hydrocracked/Hydroisomerized = API Group III base oils. Chevron, Shell, and other petrochemical companies developed processes involving catalytic conversion of feed stocks under pressure in the presence of hydrogen into high-quality mineral lubricating oil. In 2005, production of GTL (gas-to-liquid) Group III base stocks began, the best of which perform much like polyalphaolefin. Group III-base stocks are widely permitted to be marketed as synthetic motor oil with few exceptions where they are not allowed to be marketed as "synthetic" (for example, Germany).
Depends on whose definition of synthetic you're using.
For the record, as far as I can recall, the FTC agrees with Castrol, that it is a synthetic.
The issue came up originally because of hydroprocessed dino feedstocks that came out with qualities that are superior than lubricants based on first cut refinery output. The process was (IIRC) developed by Chevron and is licensed to a number of companies.
After looking at what has happened in the lubricants marketplace, I surmise the following:
1) Castrol started marketing this hydroprocessed (group III) oil and called it a synthetic. It has properties that are better than straight dino feedstocks (group I and II) but maybe not quite as good as PAOs (group IV).
2) Mobil got upset. Mobil 1, a PAO based oil, costs significantly more than a group III oil, so even though the price of Mobil 1 was significantly higher, Mobil wouldn't be making as much money, and their market share would be taking a nose-dive due to the retail price advantage Castrol would enjoy.
3) Mobil sued.
4) Mobil lost.
5) A large number of companies now market synthetics and synthetic blends at much higher price points, and much higher margins since the retail customer doesn't know what the heck the word synthetic means anymore, and they think they're getting an exotic product instead of simply cleaned up dino oil.
6) I don't like Castrol. I don't like the fact that they are virtually the only supplier of the only oils 'blessed by VW' that are commonly available in the USofA. I don't like the fact that they are selling $1.25/qt oil for $6.50/qt, or much more if you buy it from a VW dealer. I don't like people on this forum that march to the VW and only VW mantra, particularly when it comes to fluids. I mean, really, they won't go to a dealer for service, but that same parent company is the one and only place for fluids? Are you kidding me?
So if you really want a really synthetic synthetic oil, you are left with 3 choices. 1) Redline 2) Amsoil (only their top grade) 3) Motul (I have no idea what the name is, I only know they have one ester based product).
After that, you have hydroprocessed dino oil (group III, Castrol, etc.), and really really processed dino oil (processed into PAOs, called group IV, Mobil 1, some mid-grade Amsoils, [used to be Chevron Delo 400 synthetic, but they quit doing PAOs]). These are being called synthetics.
Some people think PAOs start out as natural gas in a GTL type process, but it isn't happening. Processing dino oil into PAOs is cheaper, so that is how they're produced. It could be done as a GTL, it just isn't right now.
So maybe the polyolesters used in Redline, Amsoil, (and Motul's I bet) start out as dino oil also, get blasted to atoms then recombined into a completely wacked out alcohol (yes, polyolesters are an alcohol - but they lube well, stick to metal, and have better temperature stability than any lesser group base), so it wouldn't be a GTL process either.
When it comes right down to the basics, what do you need? There's lots of good oils that will work for the VE pump engines. There's an exotic oil 'required' for PD engines. Since there are examples of both problems running the 'correct' oil, and no problems running the non-blessed type, wherein lies the fault? Is it with a barely meets spec oil sold by Castrol (because they have a virtual captive market)? Is it bad parts from the factory by VW? Is it dealers that don't know or care? Clueless owners?
I don't think we'll ever know the truth.
You're left with what do you want to consider to be a synthetic oil. I choose Redline. You choose whomever/whatever you will.
So what? It's not true synthetic, they can called any name, even win case in the court it's still not synthetic, so whenever they said it's not there.Anyone else find it odd that the OEM oil is a group III even though it isn't "true" synthetic and can't be marketed as such in Germany?
(Assuming the Wikipedia excerpt is accurate)
Also, did a search. Found this write up from Powder Hound.
See, there you go again. What are you trying to say?
Bill
So not only are you not very good at being clear with your statements, your reading comprehension is lacking as well as I was backing your point up.So what? It's not true synthetic, they can called any name, even win case in the court it's still not synthetic, so whenever they said it's not there.
But you can fill your car whenever oil and be happy. But I will not. This forum is exist for enthusiasts.
You need to read this forum http://www.bobistheoilguy.com/
So the USA is not just one country (out of the many) in the world? How many countries do you think make up the USA? Who are the 'elitists'?See your problem is you think US is just one country in the world but isn't. Those are called elitists
This thread went wrong way so let's not discuss this here you can email me.
Thanks for the encouragement to do the research. I was simply falling into the trap of believing Castrol's advertising! I had forgotten about the Mobil lawsuit, and the result of the lawsuit, and that all these companies dance around the "truth".It's not. All Synthetic Castrol is group III oils. Do more research on web.
Not that I normally agree with Phlfly on many posts, but to someone who has lived elsewhere in the world or even traveled extensively, their is an "attitude" that Americans as a whole have about their self-importance in the world. Myself included years ago before I traveled the world and saw the difference.See your problem is you think US is just one country in the world but isn't. Those are called elitists
Calculated tank averages is the normal reporting done here. Using the computer and short trips doesn't really tell you much and is subject to lots of error.I don't know but it could be sounds crazy. May be computer went nuts. I drove thru same traffic as everyday I do. The trip computer had showed 0 miles, 0 Avg, 0 speed, 0 avg speed. I will get today later after driving home. I had aircon. on for first 10 min of the trip.
I agree that the world isn't even remotely English-centered. That really has nothing to do with what was requested of the poster.Not that I normally agree with Phlfly on many posts, but to someone who has lived elsewhere in the world or even traveled extensively, their is an "attitude" that Americans as a whole have about their self-importance in the world. Myself included years ago before I traveled the world and saw the difference.
Even within the US certain cities find themselves the center of the universe, New York, LA and DC come to mind. This from someone who lived in LA and bought into the whole self-center of the universe concept.
After moving to Seattle and getting away from that self serving attitude, I saw the difference and wonder how the heck we ever drunk the koolaid so completely in the rat race.
It is obvious that since many here speak English as their mother language from birth, they fail to realize English is one of the HARDEST languages to master. Even those born into English fail to properly understand it in the US and it is painful to listen to and read. Cut those who do not speak English a break.
WE should help them understand it, not belittle or blame them for a failure to communicate. WE need to go the extra mile to understand them. I am sure you would expect the same courtesy if you lived in another country. English is NOT the only language in the world and even though my own, not the most important either.
Yea he is amazing person, people like him, Sacharov, stood against Soviet system, in the danger to be arrested and killed. Amazing people with amazing courage back in those days.Thanks for trying.
My wife and I were good friends of Mstislav Rostropovich, the world's greatest cellist of the 20th century. In person, his English was TERRIBLE, but always spoken with such charm and grace that everyone around him was...well...charmed.
ANY time he was asked to write anything, the grammar/syntax/spelling were all perfect. Why? Because he understood that the written word has to be very clear to be understood.
Got my 10,000 mile service done today. I checked the oil before the dealership changed it and it was very black. I checked it after 3 miles of driving with the new oil and it was black but seemed to have a clearer tint to it than the initial oil. I don't believe you can get all of the oil out after a change so the old oil has some "color influence" on the new oil for sure....Diesel oil turns black almost immediately after changing it...
Black tint?I checked the oil immediately after the 20K service - before driving off the dealer's lot. It had a nice tint to it. Perfectly fine!
This is not peculiar to any country or place. It is simply evidence of -centrism, be it ethno-, geo-, whatever. It is completely natural and will emerge wherever you are in whatever people live there, no matter their culture. I visited Somalia what seems like a very long time ago, and people who wore rags and herded sheep considered themselves the lords of creation. A town not so very far from us in Central IL thinks the world is flat and drops off into empty space at the borders of their township. I could go on, but you get the idea, I'm sure. As Mark Twain wrote in Innocents Abroad, travel is the best cure for insularity. He also had a good way of viewing it from the flip side:Not that I normally agree with Phlfly on many posts, but to someone who has lived elsewhere in the world or even traveled extensively, their is an "attitude" that Americans as a whole have about their self-importance in the world. Myself included years ago before I traveled the world and saw the difference.
