Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old June 5th, 2003, 19:15   #1
Frank M
BANNED
TDI(s): NB
Default Trivia Question #9
The LEAST likely cause of excessive blue smoke in the exhaust of a turbocharged engine is:
1: PCV valve stuck in the open position
2: worn turbocharger seals
3: worn valve guides
4: worn piston rings
Frank M is offline   Reply With Quote
Old June 5th, 2003, 20:02   #2
FowVay
FowVay's Avatar
I would choose numero UNO. A open PCV should not cause oil to be in the combustion chamber other than what is being vaporized through normal operational conditions.
FowVay is offline   Reply With Quote
Old June 5th, 2003, 23:35   #3
no rest till
Fuel Economy: 45-48 mpg
1, because 2,3,and 4 would cause smoke
no rest till is offline   Reply With Quote
Old June 6th, 2003, 03:48   #4
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
1
runonbeer is offline   Reply With Quote
Old June 6th, 2003, 06:30   #5
Judson
TDI(s): 2001 Jetta
Morning, Frank.
3.
Jud.
Judson is offline   Reply With Quote
Old June 6th, 2003, 06:32   #6
dieseldorf
top post dawg
dieseldorf's Avatar
1.
Old June 6th, 2003, 13:49   #7
George
Heck, what do I know? I'll opt for #2. Seems to me all the others could result in more oil burning, hence the smoke.
George is offline   Reply With Quote
Old June 10th, 2003, 04:19   #8
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
#1. The PCV valve is open part of the time when it functions normally. Any time there is positive crankcase pressure, this valve is venting. If the normal operation of this valve does not cause excessive smoke, why would extra-normal operation?
That's my rationalization, and I'm sticking to it.
Old June 10th, 2003, 19:36   #9
Frank M
BANNED
TDI(s): NB
The correct answer is #1
an open PCV will not cause the engine to ingest oil, or enough to make any smoke.
Old June 11th, 2003, 11:42   #10
Judson
TDI(s): 2001 Jetta
Huh. I thought domestics had real problems with PCV valves,
that's why I went with it.
Jud.
Page generated in 0.13977 seconds with 10 queries
[Output: 86.26 Kb. compressed to 72.53 Kb. by saving 13.73 Kb. (15.92%)]
