Old May 5th, 2008, 20:32   #1
daking
TDI(s): o right now
Default Pump Picture Thread
I was wondering if some of you guys could post some pics of the ve pumps, as much as posssilble
or if you know were i can find them please let me know
Thank You
Joel
daking is offline   Reply With Quote
Old May 5th, 2008, 20:35   #2
whitedog
If we knew WHY, we could give you a better selection of pictures.
Old May 6th, 2008, 04:35   #3
daking
TDI(s): o right now
Im am trying to compair difrent pump and how they are setup, im am looking for a good pic of the left side of the pump and the front, i tryed searching google but with not to much luck, was hoping you guys could help me out
Old May 6th, 2008, 06:32   #4
whitedog
Installed or on the bench?
Old May 6th, 2008, 17:01   #5
daking
TDI(s): o right now
complete on bench would be best but installed would be fine
preferably NON KSB
Thanks for helping me with this odd request
Joel
Old May 6th, 2008, 17:09   #6
Nico3d3
Nico3d3's Avatar
TDI(s): Golf 2001
I did find a diagram of the Bosch ve pump. Here it is:
While this diagram helped me a lot, I still have some questions regarding the mechanism inside the fuel pump. Especially the left part of the pump which is suppposed to be the low pressure part
2001 Golf TDI ALH, .205 injectors, custom chip: maf & egr delete, G60/ Sachs VR6 clutch, frostheater, 1.8T brakes
Nico3d3 is offline   Reply With Quote
Old May 6th, 2008, 20:12   #7
daking
TDI(s): o right now
yes, thank you but im looking for an accual picture of the pump, pics tell a thousand works so i just need a good pic of one, i will keep on google and see if i can find somthing
Joel
Old May 6th, 2008, 20:19   #8
whitedog
Here is a picture of the back as installed.
Here is a picture of the front without the gear.
Here is a picture withthe gear installed and showing the timing belt path.
Here is a picture of the top.
None of them helped, did they?
Old May 6th, 2008, 20:47   #9
rdkern
Fuel Economy: A4 = wife drives it, don't know
That's a clean engine. I guess I've got to go to the carwash some day soon. Nice shots. Working on a how-to? Or just trying to collect the library like dd has?
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old May 6th, 2008, 20:51   #10
whitedog
Those are from that thread in your link.
The einge was recently put in, so it's nice and clean. The accessory mount was sanded and bead blasted, so it's extra clean.
Old May 6th, 2008, 21:10   #11
ultrasparc
Fuel Economy: 42 D, 40 B100
So that what a VE pump looks like
Heres one
Wait, you probably meant for a WV application, not cummins.
This one is a little older, but you didnt specify. Like the diagram.
Here is a video of one on a bench, sounds like its gunna blow up.
If a picture is worth 1,000 words, a videos gotta be worth at least say 10,000 words ?
http://www.youtube.com/watch?v=_r6RN7vQmXw
ultrasparc is offline   Reply With Quote
Old May 7th, 2008, 19:40   #12
daking
TDI(s): o right now
ultra thats first pic is a ppump not a ve, and whitedog acualy the second pic was perfect thank you, is that the way most of the front of the pumps look like in a tdi or is that a costom retainer in picture two
thanks again
joel
Old May 7th, 2008, 20:33   #13
whitedog
Tha long, flat thing running to the lower edge of the picture is just a srewdriver. I used it to hold the hub in position so that the alignment of the TDC slots were shown.
That is what all of the VE pumps look like in the A4 cars.
Old May 8th, 2008, 18:32   #14
daking
TDI(s): o right now
i knew that was a screw driver but i was refering to the plate being held by the three bolts/screw
thanks
joel
Old May 8th, 2008, 18:44   #15
whitedog
That is the drive hub. I installed the bolts so that I wouldn't loose them; the pulley bolts to that. The one came in handy for turning the shaft.
Page generated in 0.21367 seconds with 10 queries
[Output: 113.87 Kb. compressed to 93.46 Kb. by saving 20.41 Kb. (17.93%)]
