Maillemann
'96 B4 Passat. About three miles from home the oil pressure alarm went off, I shut it down and pulled over immediately. No loss of oil, no leaks, didn't see or hear anything unusual. I did notice it was unusually rough to start, cranking longer than usual. I also restarted it briefly after checking things over and it did so without hesitation. I was getting just under 10 psi on the gauge at idle, then shut it down and had it towed home.
This is only the second time in 14 years this car has left me stranded, so I'm not even that mad, honestly. Last time it was the intermediate shaft which broke its flange, so that was replaced along with its bearings (and pretty much everything else). So I'm thinking oil pump itself? Or could this be something like a blockage or collapsed filter? I haven't had time to tear it apart yet and would like suggestions to troubleshoot.
