db123
I bought a cam kit from Bora which came with the non tty bolts. I think these came from Franko6? Just wondering whether the bolts should be oiled before being installed or do they get installed dry? Also final torque settings are 144 in-lbs for the bearing caps and 25ft-lbs for the rocker arms and the end bolts on the rocker arms to 22ft-lbs, is this correct.
Thanks.
Thanks.
