shortysclimbin
Hmm.. I will need to check on this. The idea is to decrease the roller diameter but keep the spacing the same for the normal one. Then a second roller will be located with a customer spacer and diameter above the water pump but between the alt. A custom bracket will be needed for this as well. This would result in a lower belt setup similar to this:
Optionally, a slicker design, would be to create a custom water pump housing that allows for a VR6 12v waterpump to be used in it. doing this would mean you just change the water pump, housing, pulley, and belt for a very tight and off the shelf package down the road.
Stock water pump housing:
VR6 pump (note it runs reverse from 1z/ahu and 6A motors)
https://www.ecstuning.com/b-graf-parts/water-pump-with-metal-impeller/021121004x~grf/
Maybe you can come up with a custom housing offering? your tooling setup is perfect for it and honestly a lot of us running these engines would use it.
Benefits include:
1) elimination of the v belt that always flies off or slips (causing power steering to stop and water pump to stop)
2) increase clearance in engine bay by ~15mm. this is especially important for swap guys
3) increased life of belts and water pumps.
4) potential for heavier duty belt use (I need to check on this with gates)
Benefits include:
