Old January 17th, 2019, 11:23   #46
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Originally Posted by sportwagen3 View Post
Here's all the PID that I'm using that works within Torque.
Name ShortName ModeAndPID Equation Min Value Max Value Units Header
VW Exhaust Temp 3 DPF IN 178 (((F*256)+G)/10)-40 0 1500 °C Auto
VW Exhaust Temp 4 DPF OUT 178 (((H*256)+I)/10)-40 0 1500 °C Auto
VW DPF Soot (Measured) Soot 06b2 ((R13<8)+R14)/100 0 30 g Auto
VW DPF % DPF % 018b (C*100)/255 0 100 % Auto
VW Regen Regen 018b Équation {B:0} 0 1 Auto
VW DPF Soot (Calculated) Soot 06b2 ((R40<8)+R41)/100 0 30 g Auto
Thanks ill check this tonight
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old January 18th, 2019, 05:31   #47
740GLE
What epa fix do you have phase 1 or phase 2?
Old January 18th, 2019, 06:06   #48
sportwagen3
phase 2
sportwagen3 is offline   Reply With Quote
Old January 18th, 2019, 07:19   #49
GreenLantern_TDI
Me too and DPF% still doesnt display on torque.
Old January 18th, 2019, 09:09   #50
KERMA
KERMA's Avatar
http://forums.tdiclub.com/showthread.php?t=481602
This app does everything you want, uses the same hardware as the Torque app, and it's also available in a free version
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old January 18th, 2019, 10:24   #51
sportwagen3
Main reason I'm using Torque is because I can get it to display on Android Auto (I did the MIB2 conversion) via OBD2 for AA. VAG DPF doesn't work on AA.
Old January 18th, 2019, 10:24   #52
sportwagen3
It works for me. I copied all those values directly from my PID file.
Old January 18th, 2019, 10:28   #53
Lightflyer1
Lightflyer1's Avatar
Doesn't work for all models. I have it working for some of my modules (CVCA) but not all. Been in contact with the owner over seas but he isn't interested in doing much to modify for the US cars due to special equipment needed he says to take readings he needs. Maybe some of you "hardcore" guys with equipment could help him out. I tried with VCDS and he said it isn't the right tool for the job. You can/may be able to get some to work by trying different models.
Old January 18th, 2019, 13:35   #54
740GLE
well there's always polar FIS
Old January 18th, 2019, 15:59   #55
GreenLantern_TDI
Did they get all the bugs outa that yet?
Old January 18th, 2019, 16:08   #56
bigb
That's what I'm waiting for too, the bugs
bigb is offline   Reply With Quote
Old January 24th, 2019, 08:27   #57
sportwagen3
I've noticed scan gauge updated some additional information related to DPF such as average distance between regen and DEF level %. Anyone know how to convert these into PIDs?
https://www.scangauge.com/x-gauge-co...e-2-0l-diesel/
DPF regen hawleyrw VW MKVI-A6 Jetta Sedan (~ 2011+) 11 October 25th, 2012 02:12
Bmw dpf monitoring chriz1 Non VW Group Diesels 2 October 22nd, 2012 09:01
Dpf regen hb9001 VW MKV-A5 Golf/Jettas 8 September 13th, 2012 04:18
DPF regen? dpg VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 20 December 31st, 2011 13:49
DPF regen?? John and the GTi VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 July 2nd, 2010 11:25
Page generated in 0.14270 seconds with 12 queries
[Output: 113.01 Kb. compressed to 95.62 Kb. by saving 17.39 Kb. (15.39%)]
