A5 Golf / Jetta Mk5 02Q 6 Speed Tranny Conversions
Status
Not open for further replies.
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
I keep getting asked for a long ratio 6 Speed Setup for the A5 Golf. I've sold a few of these without advertisement so far, now it's time to actually make a topic about them!
These come with all the items you see in the picture. This is everything you need to upgrade from a 5 Speed Manual to the 6 Speed.
5 to 6 Speed Parts list:
02Q 6 Speed Gearbox
2 x Drive Shafts
Used Dual Mass Flywheel and Complete Clutch Kit
Gearbox Mount (bolted to box)
Dog Bone Mount
Starter Motor
Dust Tins between Engine/box
Linkage Cables
Cable Mount and End Links
6 speed Gearknob and boot
All bolts required including New where needed
The price for the complete conversion is £1600. Please bear in mind that £300 of the cost is for shipping alone! I include ALL the bolts required for the conversion, including new bolts where the original are single use only.
I can include BRAND NEW VW/SACHS DUAL MASS FLYWHEEL, CLUTCH KIT and RELEASE BEARING, With this the complete kit will be £2000 INC SHIPPING
From my research there are 2 main groups of subcode with the same ratios (there are 4 groups in total, but the other 2 have almost the same ratios as the 5 speed so I have left them out).
They are all based on the 02Q Box, which is an uprated version of the 02M found in the A4 Golfs. The difference being the lack of a speed sensor and strengthening to the casing on the 02Q.
02Q 6 Speed Group 1
1st 3.769 - 2nd 2.087 - 3rd 1.324 - 4th 0.919 - 5th 0.902 - 6th 0.757 - Rev 1.643 - FD1 3.684 - FD2 2.917
02Q 6 Speed Group 2
1st 3.769 - 2nd 2.087 - 3rd 1.324 - 4th 0.977 - 5th 0.975 - 6th 0.814 - Rev 1.643 - FD1 3.45 - FD2 2.76
The 02Q Uses 2 final drives. FD1 for 1st - 4th, FD2 for 5th & 6th.
02J 5 Speed - GQQ, JCR - For comparison
1st 3.778 - 2nd 2.063 - 3rd 1.348 - 4th 0.967 - 5th 0.744 FD 3.389
With the Group 1 ratios, you are looking at about 100mph in 6th @ 3000RPM with 205/55/R16 Tyres. The Group 2 would be @ 98MPH.
This compares to 88MPH in 5th on the 5 Speed, a very nice increase!
To put it another way, at 75MPH the BRM 5 Speed is @ 2555RPM, whereas the 6 speed is @ 2237RPM (318RPM Decrease), with 205/55/R16 Tyres.
Here is a topic from a while ago discussing the A5 conversion:
http://forums.tdiclub.com/showthread.php?t=302432
ducesrwld
WI
none
one of the few stealth brm 6 speeds around well worth the dough. i believe stock rpm more like 2700 rpm @ 75 mph now it's around 2250 rpm significant drop. and i wouldn't call this an interstate only gear @ 65 mph you are crusing at a solid 2000 rpm. start saving your pennies....
ryanp
Ryan, Did you figure the guide out that we discussed a while ago? I'm 99% sure this is just the same conversion as the Mk4 / A4. It looked that way when i swapped out the box on my Mk5 Jetta anyway!
I've one long ratio conversion in stock!
Ry
m1ketdi
Leam
Leon BKD
Ryan, is group 1 the ratios from the 170? I feel sixth in the leon is a bit short.
ryanp
Some 170s, not all, the CRs are hit and miss too. About 200rpm or so in it IIRC
ryanp
Shipping one of these tomorrow with a nice Peloquin LSD in there!!
ryanp
I still have access to these if anyone is curious!!
Status
