Old December 2nd, 2019, 09:34   #1
Chichi2k
TDI(s): 1.9 tdi
Default Sdi pd camshaft into TDI PD
I know that there are some threads on this but , is actually someone rolling with SDI cam in TDI PD ? I am looking to install a 2.0 GOLF 5 SDI cam into 1.9 AVF soon . I previously owned a Seat Leon 1.9 ASV which ended up with 240HP . Among alot of mods , i used a SDI cam into it . Because i knew my car , the difference was immediately , i noticed a stronger exhaust sound , and increse in torque , starting from 1900RPM car was noticeably more aggresive and rpm went up quicker . I wish if someone installed SDI into PD can say something about how he felt the car after . Cheers .
Chichi2k is offline   Reply With Quote
Old December 2nd, 2019, 12:19   #2
Zak3
I think itís the same camshaft for all 4cyl PD engines !
Zak3 is offline   Reply With Quote
Old December 2nd, 2019, 23:34   #3
Chichi2k
TDI(s): 1.9 tdi
Well , its not the same oem code. And if u ever drove sdi u will find it nicer to drive than a tdi without turbo working.
Old December 2nd, 2019, 23:48   #4
adamss24
Fuel Economy: 35-45mpg
It might be different OEM code but unless you swap it over we wont know the difference ! What e meant is there is little difference between cams and you're better off spending your money on other modds...
adamss24 is offline   Reply With Quote
Old December 3rd, 2019, 00:45   #5
Chichi2k
TDI(s): 1.9 tdi
Well its sure that it has higher duration on injectors and that s a start. Uneducated guess tells me at least 10 15hp gain
Old December 3rd, 2019, 04:40   #6
bhodgkiss
Doesnít the PD camshaft have extra lobes for injectors?
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old December 3rd, 2019, 05:58   #7
Yourbuddysatin
Fuel Economy: 32-35mpg
Yes. 3 lobes per cylinder.
Yourbuddysatin is offline   Reply With Quote
Old December 3rd, 2019, 06:49   #8
Chichi2k
TDI(s): 1.9 tdi
Ofc it has lobes that press on injectors . So i assume that for SDI injector lobes are different so that s where duration difference come from
Old December 3rd, 2019, 08:38   #9
turbobrick240
turbobrick240's Avatar
I believe the main difference is the exhaust valve lobe duration. Gains should be mostly on the low end of powerband. Probably quite useful for spooling a big, lazy turbo.
Camshaft caddy sdi pd or oem camshaft arl? Boyka TDI Power Enhancements 14 February 19th, 2017 12:37
tdi pd 16v 2.0 bkd camshaft specs fergyp TDI 101 0 February 17th, 2017 05:01
Camshaft 2.0 Sdi in 1.9 TDI PD corsabala TDI Power Enhancements 8 June 15th, 2016 09:58
camshaft timing on tdi PD cuprapower TDI Power Enhancements 7 August 10th, 2013 08:48
sdi to tdi PD conversion the slob TDI Conversions 0 May 31st, 2010 13:14
Page generated in 0.13218 seconds with 11 queries
[Output: 86.95 Kb. compressed to 74.34 Kb. by saving 12.61 Kb. (14.50%)]
