Old July 4th, 2019, 14:04   #16
Genesis
Fuel Economy: 53/48/42
I was gonna say "the clutch is well under $100 from the usual vendors here" 'cause I've changed one myself..... the tool bits to do it aren't very expensive either, assuming you don't know anyone who has them in their toolbox.
Genesis is offline   Reply With Quote
Old July 4th, 2019, 16:08   #17
ScottSwee
Idparts is great. I order most everything from them. Wish I would have ordered my alternator from them originally instead of O’reilys.
ScottSwee is offline   Reply With Quote
Old July 5th, 2019, 11:25   #18
Nevada_TDI
Mine recently started itself on fire due to a frozen bearing making the alternator have a zero core value...
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old July 5th, 2019, 15:39   #19
Den
Fuel Economy: 45 - 55 jetta, passat CURRENT BEST HIWAY 50 MPG.
Default alternator issue
While driving to work the other day the car made a horrible thumping sound and quit. Had it towed , then after removing all the crappy plastic panels found that the alternator pulley had come of the alternator. So I replaced the alternator with a new one and a new belt and now the car will not start?
What the heck is going on?
2014 PASSAT SE TDI 6 SPEED DSG. 2001 Jetta TDI, GLS, 5 speed. VA-VW10, 42 D.D. TDI Solutions 1, PP520, Mufflerectomy, Ventectomy, Power Service, 0.681 5 th gear set, and race pipe.
Motorcycles, Diesel cars, motorcycles, Diesel cars,....
Den is offline   Reply With Quote
Old July 5th, 2019, 15:54   #20
ToxicDoc
TDI(s): 2001 Jetta
You should start your own thread for this. Will it crank?
ToxicDoc is offline   Reply With Quote
Old July 5th, 2019, 20:35   #21
ScottSwee
Wow that is too bad.
I agree you should start your own thread
Old July 6th, 2019, 05:39   #22
Den
cranks like crazy just no fire. sorry I saw the alternator issue and just got on.
Old July 6th, 2019, 06:40   #23
ScottSwee
Not a problem. I think you will get some better help if you tart a new thread
Old July 6th, 2019, 09:23   #24
ToxicDoc
TDI(s): 2001 Jetta
Yes, start a new thread please and we'll help you
Old July 8th, 2019, 21:09   #25
ScottSwee
Wondering if you were able to get your core back with a new pulley?
Any updates?
Old August 28th, 2019, 13:53   #26
Tankthecarman
Tankthecarman's Avatar
Fuel Economy: 42-48
I got the old alternator back from AZ, and got the pulley/sprag from IDParts. I had to get a second reman BOSCH from AZ before my pulley came in, so I have to assume it will work as it did originally. Luckily I have it sitting on the shelf and my daughter’s 02 Beetle has the same ALH engine so if hers fails I have one to swap in immediately. Thanks for the help and suggestions CSSTEVEJ!
Last edited by Tankthecarman; August 28th, 2019 at 13:55. Reason: Friggin’ autocorrect gets me every time!
Tankthecarman is offline   Reply With Quote
Old November 25th, 2019, 13:17   #27
Tankthecarman
Fuel Economy: 42-48
Ive been running this second reman unit from Auto Zone for several months now. It’s plugging right along. Thanks for all of the help, suggestions and assistance with finding the right parts to fix my old stuff!
alternator issues Trev21 TDI 101 8 September 25th, 2014 15:33
Alternator issues blueavlo VW B5 Passat TDIs 9 July 12th, 2013 15:07
Alternator Issues EMSi VW MKIV-A4 TDIs (VE and PD) 3 April 10th, 2011 08:21
Alternator Issues jsmith4425 Upgrades (non TDI Engine related) 6 January 19th, 2009 14:35
alternator issues moe03 TDI 101 4 December 6th, 2006 16:15
Page generated in 0.16238 seconds with 11 queries
[Output: 104.94 Kb. compressed to 88.14 Kb. by saving 16.80 Kb. (16.01%)]
