Old December 20th, 2013, 13:14   #1
rf2009
TDI(s): 04 Golf
Default Small studder
Im getting a small studder comparable to a missfire in a gas engine. it only happens after sitting for 8+ hours, and always happens when an approximate distance has been traveled (about 1 mile). it studders twice (at a constant speed about 60mph) and never again for the rest of the day. any ideas?
rf2009 is offline   Reply With Quote
Old December 21st, 2013, 20:39   #2
Second Turbo
Fuel Economy: 38
Default Millions of reasons. Here's a guess.
Sounds like it's happening at warm up. Our 2003 ALH is doing the same, but is also throwing a MIL shortly after start if air temp is below freezing. We had the dealer check it, and the code is for the EGR, which needs either replacing or cleaning. Tech suggested waiting until it becomes a problem (we're at 306,000 miles).
Does the EGR in an ALH (or PD, you didn't say) engage at start, or after warm-up?
Second Turbo is offline   Reply With Quote
Old December 22nd, 2013, 06:07   #3
CopaMundial
Look here in this thread to find your new mechanic.
http://forums.tdiclub.com/showthread.php?t=130044
Welcome to the TDIClub forum. If this community forum helped you save money on a purchase or repairs, please consider donating just a small percentage of what you saved using the 'donate' link HERE. Donations keep the forum going. (note: I'm not affiliated with TDIClub or Fred... I just can't imagine the world without either of them)
CopaMundial is offline   Reply With Quote
Studder / Stumble at idle NWA-TDI VW MKIV-A4 TDIs (VE and PD) 5 April 19th, 2013 08:40
idle studder... at odd times Jesse_Boyer VW MKIV-A4 TDIs (VE and PD) 15 December 12th, 2009 16:04
Studder on climbing hill. TomB VW B5 Passat TDIs 3 May 16th, 2006 09:19
TDI studder and stall Jedi99 TDI 101 3 August 19th, 2003 13:33
Engine Studder Boone VW MKIV-A4 TDIs (VE and PD) 2 November 6th, 2002 11:59
Page generated in 0.15272 seconds with 11 queries
[Output: 57.70 Kb. compressed to 52.47 Kb. by saving 5.22 Kb. (9.06%)]
