Old November 29th, 2013, 06:42   #1
striker
TDI(s): None
Default 2006 & 2013 Jetta Alternators Interchangable?
I have a 2006 Jetta that now needs an alternator....a new one is over $300 and just isn't in the books right now.
I found a few used ones from $100-$150. One in particular was off a 2013 and I like that because the piece would be relatively new.
Does it fit? If not, what other years can I look at besides the MK4 cars because that's getting old now.
striker is offline   Reply With Quote
Old November 29th, 2013, 06:54   #2
dandywriter
It may not be the alternator; it might be cheaper, like the fuse. See
http://forums.tdiclub.com/showthread.php?t=328251
It might be a $2 fuse... I know of another person with an 06 who was about to buy an alternator, and it also turned out to be the fuse.
dandywriter is offline   Reply With Quote
Old November 29th, 2013, 07:29   #3
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
idparts sells the same alternator for the BRM and CBEA/CJAA engines, so it should work... http://www.idparts.com/catalog/produ...vl3ec0elq79kt5
Yuri
(You said 2013 - Passat or Jetta/Golf?)
(Is your 2006 a sedan or a wagon? Different engines...)
Quando omni flunkus moritati
ymz is offline   Reply With Quote
Old November 29th, 2013, 08:36   #4
striker
TDI(s): None
My car is a 2006 Jetta (BRM) and the pulley ended up going toast. Long story short, I ended up getting an alternator this morning from a local yard for $101 tax in.
It came off another 2006 with 180,000 kms. Now that I think about it, I should have went with the 2013 model alternator they had off a 2013 TDI for $50 more :S
Old November 29th, 2013, 10:07   #5
A5INKY
Fuel Economy: pretty good
Or you could have just replaced the pulley without removing the alternator from the car. New OE quality pulley is roughly $60. True you need the special tool, but $30 will buy that, or I'm sure it could have been rented or borrowed. BRM alternators are nearly bulletproof, it is pretty much always the pulley that fails.
A5INKY is offline   Reply With Quote
Old November 29th, 2013, 12:20   #6
striker
TDI(s): None
That was the plan, to replace the pulley only. However, the tech doing the job cracked casing so I ended up with a new/used alternator for the price of a new pulley.
H&R Sport Springs: 2011-2013 Jetta TDI CaliforniaTDI Private TDI Items for Sale/Wanted 2 June 6th, 2014 17:23
2013 Jetta Tach & Speedometer Jumping TDI AP TDI 101 13 November 21st, 2013 15:43
Request Info. on R & I of TDI 2.0 Eng. in 2013 Jetta HighFly27 VW MKVI-A6 Jetta Sedan (~ 2011+) 0 October 5th, 2013 06:50
Will wheels from a 2006 Jetta fit a 2013 Passat? Kirk TDI 101 3 July 18th, 2013 11:26
2013 Jetta TDI upgrades & differences? Gee Spoolin VW MKVI-A6 Jetta Sedan (~ 2011+) 11 July 18th, 2012 11:32
Page generated in 0.14564 seconds with 11 queries
[Output: 73.21 Kb. compressed to 64.01 Kb. by saving 9.20 Kb. (12.57%)]
