Old December 1st, 2009, 19:31   #1
Jesse_Boyer
Default idle studder... at odd times
Recently, I bought another TDI to have as a spare, but I'm struggling to figure out an idle stumble. The car seems to run perfectly down the road at all speeds, but experiences an odd stumble while rolling to a stop. I can hear the motor start to stumble at approximately 7-10mph, but it completely smooths out when the car comes to a stop. It may be starting before 7mph, but I can't really hear it until that point. It will do it if you start from a stop, let off as soon as the car is moving, and listen... forward or reverse.
Any suggestions would be appreciated.
Jesse_Boyer is offline   Reply With Quote
Old December 1st, 2009, 21:00   #2
Wook660
Wook660's Avatar
Fuel Economy: 48 mpg
search "slow down shutter" "Injection Quantity Adjustment" and "Hammer Mod" and see if they relate to your circumstance
2002 Jetta TDI AT Sold.
2001 Jetta TDI MT going the distance! - 350K...
1988 Samurai, soon to be diesel?
Mahindra 4530 Diesel!
Wook660 is offline   Reply With Quote
Old December 3rd, 2009, 09:18   #3
ofhs93
Fuel Economy: 51/46/42
As Wook stated...Check the IQ...I'm willing to bet money that is your issue...it's not at all uncommon with these
A recently overheard convesation involving a car enthusiast and one of our Guru's:
Luke S.: [on first seeing the "Ghostly" gray/blue 99.5] What a piece of junk!
TDIJetta99: She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself.
99.5 Black Jetta 5spd: 178k RC3 + PP520s =
03 Silver Jetta GLS 5spd: 175k MFA cluster, Hella E-Codes, rear fog, no power mods...for now
ofhs93 is offline   Reply With Quote
Old December 3rd, 2009, 09:23   #4
Ski in NC
Fuel Economy: 48-52 typical
Mine does that and has for several years. I just ignore it.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old December 3rd, 2009, 16:55   #5
Jesse_Boyer
This was my suspicion as well. I'd read about it on this forum, but didn't have VAGcom to check. I know a local 'tdi guru' and checked with him to see if we could use his VAGcom to check on the IQ. The IQ was 1.0-1.2 and after some adjustment, it's 3.4-3.6. The 'guru' spent nearly 90-minutes, charged me $50, and didn't fix my 'slow down shudder.' I'm slightly frustrated with my evening thus far...
Any other thoughts, gang?
Old December 3rd, 2009, 17:29   #6
Wook660
Wook660's Avatar
I toyed with my IQ setting for a while and was able to cure the problem. Eventually my IP started going bad and I was unable to set the IQ. The value would fluxtuate back and fourth as did the timing on the graph. Not saying your pump is bad, but I had to replace mine with a cheap used one I bought off a fellow member that is currently working great. I'll send my original pump out for overhaul when my next TB is due.
How many miles are on the car?
Old December 3rd, 2009, 17:37   #7
Jesse_Boyer
205k
Can anyone tell me why the 'studder' happens when rolling at very low speeds, but completely goes away once the car stops?
Timing and IQ were quite solid per Vagcom
Old December 3rd, 2009, 18:56   #8
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
What is the IQ though? I had it for years.
Here is a how to I made...
http://forums.tdiclub.com/showthread...95#post2689895
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old December 3rd, 2009, 18:59   #9
Wook660
Wook660's Avatar
Maybe this is related to the DMF and not the engine.
Old December 3rd, 2009, 21:42   #10
Jesse_Boyer
brand new OEM clutch. Rrolling' speed should not matter regarding idle, clutch or otherwise, right?. It's unmistakable though. You can hear it start as car slows down and it completely stops as the car stops.
IQ is 3.4 as stated above.
(going to bed)
Old December 4th, 2009, 05:16   #11
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Hmm...I can set a IQ is less than 5 minutes. Either 1. you have a bad guru or 2. you have a bad pump. At 3.4, you should not have any shuddering.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old December 4th, 2009, 05:50   #12
Jesse_Boyer
As can I, but I don't have VagCOM. Needless to say, I'll be ordering it ASAP.
He actually spent most of the time tinkering around, doing things I didn't ask him to do. Yes, I know there are issues I have to solve with that car... but I don't need or want to pay you $50/hr to do 95% of them.
Regardless, can this still be an IQ issue? It's set at 3.4mg/st... which I thought was optimal for most cases.
Old December 4th, 2009, 06:38   #13
Growler
Got Soot Vendor
Growler's Avatar
perhaps yours needs adjusted to be a little higher. I know if I had charged someone to set their IQ, and they weren't happy, I would do my best to make it right.
have you discussed this with your guy?
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old December 4th, 2009, 07:27   #14
Ski in NC
I'm a novice on this electronic diesel, but the way I understand the "slowdown shudder" is that engine is operating on one control map when car is moving, then transitioning to another map when car is stopped. In that transition, it "hands off" from one map to another and if iq is so and so, it does it smoothly. If iq is off, it will shudder. Not a big deal, and I am certainly used to it.
Old December 4th, 2009, 19:33   #15
Jesse_Boyer
I'm going to do a bit more research and order VagCom later... then I'll try to tweek the IQ.
ordering the timing belt kit this weekend as well... so I'll need it anyway.
Page generated in 0.13851 seconds with 10 queries
[Output: 123.87 Kb. compressed to 102.62 Kb. by saving 21.25 Kb. (17.16%)]
