Closed Thread
Old January 25th, 2009, 06:32   #151
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
FYI here is a second version. This one only has the four page TPI that was the basis of the fix. No parts list or photos of the two different pump assemblies are included in this one. Both of the pdfs are available:
Short version:
http://pics.tdiclub.com/data/500/BHW...I-original.pdf
Longer with parts/illustration version:
http://pics.tdiclub.com/data/500/BHW...pGear_TPI1.pdf
2015 Golf SE TDI with DSG, 88k.
and formerly a 2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline
Old January 25th, 2009, 10:49   #152
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Originally Posted by aja8888
You are probably right. All I have gotten is a run around from Impex. I wish I could post the string of e-mails I have recieved from them in the last two + weeks.
Not to doubt you and your angst for not getting the parts but they get the same from VW. they will tell you what they are told. It's that simple....Seriously. They are stand up guys.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline
Old January 25th, 2009, 10:55   #153
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Stand up guys? School is out on that for me. And I won't go into the details on why I got frustrated from a lack of response(s). Another thing I did not like was that they charged my credit card for $1345.00 immediately, knowing full well they had no idea when they could ship me the parts.
It took me three or four days, two e-mails and one phone call to get the charge reversed and cancel the order.
Every online retailer I do business with will NOT CHARGE my card until the order ships.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline
Old January 25th, 2009, 12:55   #154
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
ok I just looked over the PDF and I'm confident doing this procedure.. no problem.. I'm missing a few of the tools, which I will get if someone needs this job done.. I'm guessing I'll have the same trouble getting the parts as everyone else though
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline
Old January 25th, 2009, 16:57   #155
volkswagendude
+1 That is how it should always be.
volkswagendude is offline
Old January 25th, 2009, 18:47   #156
MOGolf
MOGolf's Avatar
Before this thread gets too cluttered with comments that are not related to the replacement procedure , here are pictures of the alternate puller suggested by ScotR.
And the pressure plate that comes with it (use instead of 30-11). Note that it fits into the crank pulley bolt hole and has an o-ring to provide friction to hold it there.
This tool is installed over the end of the crankshaft. The diameter of the opening in the "bottom" is just big enough for the crankshaft. The pulling legs are meant to fit into the holes of the replacement gear. They are not spaced for the existing sprocket on the crankshaft. They need to be ground and shaped a little to fit the hole spacing.
The pressure screw has a 24mm head whereas the T40001 has a 19mm head. The counterholding hex on the body is 32mm.
Now I need a volunteer to try this out on. I know one other member obtained one of these and may use it soon.
MOGolf is offline
Old January 26th, 2009, 17:31   #157
DickSilver
I received my UPS shipment from Impex early this evening. One well-taped box with the geared balance shaft module in a very flimsy VW/Audi box inside, and all the other parts, each in its own bag. All checked on the Impex list, PLUS what looks like a new timing pulley, 038-105-263-F. Gotta check that one with my mechanics at Fast Enough Performance in Lexington Wednesday morning.
It is useless getting angry at your car: don't let nuthin' whup you that can't talk....
B5.5V TDI, chainless, Rocketchip 2, No EGR, 170K
2012 Golf 2.5, 4 door
DickSilver is offline
Old January 26th, 2009, 17:36   #158
MOGolf
MOGolf's Avatar
That is the part number for the crankshaft timing belt pulley. There should be no need to replace it, but the 045 105 229 bolt that holds it on gets replaced.
MOGolf is offline
Old January 26th, 2009, 18:33   #159
DickSilver
MOGolf - As I examine the Bentley manual and the BHW engine BS Module replacement that you and Oilhammer authored, I interpret that when the toothed (timing) belt crankshaft pulley is replaced, the engine must be at #1 cyl TDC exactly, and that the pulley is held in place with tool T10050. Then the new bolt 045 105 229 is torqued to spec. There appears to be no keyway or other pinning device: the toothed belt pulley is just held by friction under the torqued-down bolt. Am I right? Do I make sense?
Old January 26th, 2009, 18:51   #160
MOGolf
MOGolf's Avatar
The pulley is not replaced, it is reused and reinstalled. The crankshaft has a flat spot. The pulley has a D shape on the back to fit the crankshaft.
The T10050 is NOT used to counterhold the crankshaft. Do not have it in place while tightening the bolt. I recommend the Metalnerd Crank Yank tool to counterhold the crankshaft.
The engine is set to TDC at the proper time of removing the timing belt. It remains there throughout the procedure. If properly held in position while removing/installing the bolt, the crank won't move far. It can be realigned and the T10050 reinstalled for belt installation after the bolt is tightened.
It would be a safe practice to install the timing belt with the crank pulley bolt reasonably tight. Once the belt is installed, and locking tools removed, the final torque could be applied to the crank bolt. This would ensure that there is no chance of turning the crank too far without the camshaft turning.
MOGolf is offline
Old January 29th, 2009, 17:25   #161
DickSilver
I was delayed a full day by the big ice & snow storm, but this morning all the main roads were cleared and I was able to get my 2004 B5.5V driven to Fast Enough Performance for the geared BS replacement. Tomorrow, maybe, I'll have an improved car!
Old January 30th, 2009, 14:56   #162
jennogle
jennogle's Avatar
Fuel Economy: 48/36
Angry I finally got my car back!
As I posted before, my car's chain broke on November 22nd at a little over 80,000 miles. Due to lack of parts availability, I finally got it back just one week ago (January 23rd). That's TWO MONTHS without my car. Even scarier is the cost of the repair (including replacing the turbo and other parts damaged by the broken chain) came to over $4500! Ugh.
My mechanic (MF Auto in Knoxville) did an excellent job, and the car is now running great again, but I can't say I will recover any time soon. I urge any of you who are on the fence about not having this repair done preventatively to THINK TWICE.
Jenn
Silver 2005 Passat GLS TDI Wagon
jennogle is offline
Old January 30th, 2009, 15:05   #163
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Default don't stop now!
Jenn, you need to see this thread and make sure you let VOA know about your problem, and SAVE ALL YOUR OLD PARTS!!!!
http://forums.tdiclub.com/showthread.php?t=234994
oilhammer
www.cardocautomotive.com
oilhammer is offline
Old January 30th, 2009, 15:10   #164
jennogle
jennogle's Avatar
Fuel Economy: 48/36
Default Talking to VW
Yup, I am working on a letter to VW now. Matt saved the old parts, both for me and to show other customers what can happen to their cars. He also took pictures of my car before he made the repairs. I plan to send the complete invoice, photos, and letter to anyone at VW or elsewhere who will listen.
Jenn
jennogle is offline
Old January 31st, 2009, 08:51   #165
deming
Fuel Economy: 38-44
Here is the $64,000 or in Jenn's case the $4500 question----
At what point should we have this procedure done ?
We have two 05 Passat TDI wagons and thus far they have both been good cars for us. They both have the VW extended service contracts for 7 years or 100,000 miles and we purchased both of them new. I change the motor oil every 7000 miles using 505.01 motor oil and we maintain them well. One car has 30,000 miles and the other has almost 40,000 miles.
My fiance says we should just drive them until they blow and then make VW extended warranty fix them. We all know the probelm with that scenario.
Do we bite the bullet and take them down to Oilhammer and spend $3000 per car or do we trade one of them off and say the heck with it.
Jenn just spent $4500 on her car and has been without the use of her car for quite some time. That is a big chunk of change!
If VW corporate would provide me all of the parts Oilhammer will need for the updates (at no $$ charge), on both of our 2005 TDI cars, I would gladly pay the labor. I can eat $3000 in labor, but VW should step up to the plate and at least cover and provide the parts.
Dieses issue ist ein GroBe Problem for VW and fur mich!
Deming
deming is offline
Closed Thread
Page generated in 0.17715 seconds with 10 queries
[Output: 126.73 Kb. compressed to 105.70 Kb. by saving 21.03 Kb. (16.60%)]
