03 Jetta wagon
Things done
Fuel filter
Timing belt
Timing (have vcds) set just slightly retarded with specified and actual matching
Glow plug vcds mod as well as contact cleaner gp harness. May still need to replace.
Egr/cooler/cat delete. Race pipe installed solenoid delete. No tune.
Vnt actuator
Thermostat (was staying open when I bought car)
Got the car with mostly clogged intake so started there. Found Vnt actuator rusted through. Car ran a lot better after getting boost back but at start up it smokes like crazy and stinks like diesel. Once car is up to temp smoke mostly goes away but raw diesel smell remains. If I stop at a light and have the wrong wind or none at all car reeks in no time. When I was doing my timing I noticed my cold start injector duty cycle was at like 56% when a nuts was at like 5% while doing his timing. Also took car for a drive with vcds still on and duty cycle remained high all the time. This was all at operating temperature. New to vcds so any help is appreciated.
I am a diesel locomotive mechanic so I'm not a complete idiot but could use some help.
Mike
Things done
Fuel filter
Timing belt
Vnt actuator
Mike
