vw4life
yah, how the heck do you get the time and energy?????? I'm jealous what line of work are you in that affords you this "project time?"raymor said:Congratulations...think I need to get in on your time management secret
Hey I would LOVE to pick your brain about this...TDIsyncro said:Thanks guys, I get very pumped doing these projects. I guess I do have a lot of energy. VW4life, I am a mechanical designer for industrial process facilities. I work 40-50hrs a week, so not a lot of free time. I have other non-car related projects that seem endless too. Last year I set up for heating my home with grain, so there was storage, and grain handling/cleaning facilities I had to build and set-up. If you look in my u-tube vids, you can see that stuff there. Also designed and built my own snow blower last winter..7' wide, 36" high, 32"dia blower wheel, 3pt hitch mount. Then there are the wifes projects...
TDIsyncro said:Here are the pictures, as promised.
This is the 01A transmission Torsen Differential cover and differential assembly. This is what splits the torque to front wheels and back wheels.
To convert the car to a rear wheel drive, the diff has to be replaced (and there is nothing available) or it can be locked the old fashion way by welding. There are 3 sets of small gears around outside of the diff assmebly that work in the torque biasing. When these are welded solid to one another, they can no longer torque bias and transfer power to front and back differentials without descretion. If you look closely in this picture, you can see the weld on one of these gear pairs. Too weld the gears, the diff must be pressed out of the housing, cleaned with solvent, wrapped very well to prevent stray spatter from getting in the rest of the parts, brushed, thouroughly cleaned and then pressed back into cover. A new set of seals are required during reassembly.
Installation required dropping the exhaust, drive shaft shroud, and front driveshaft CV connection. The diff cover can then be unbolted and tapped off with a hammer.
This is the transmission without the diff and diff cover. Note the spring in the center..do not loose!
With the welded diff now installed, the front axles need to be removed so the driveline is not put under undue stress. Another option to the RWD set-up is to leave the front axels in place, and completely remove the rear drive shaft. The car would then be FWD instead of RWD.
When the front axles are removed, they must be replaced with outer CV joints so that the front wheel bearings have support and the ABS ring is available for the ABS system. The picture shows what you install. Just pop of the end of the axle, remove the bearings and cage, and clean out the grease.
Job done.
I am now set-up for using a local dynometer for further tuning and testing. Frankly, the tires spin so easy now its would be annoying to drive like this all the time. I will switch back to AWD in the late fall for good winter traction. I think next spring I will install a Stassis or Quaiffe rear diff LSD and run RWD again. I think that will be a really sweet set-up.
esorense said:Hi, nice build you got here I have a couple questions regarding your flywheel installation. Hopefully you can help me. I received my ECS stage 2 clutch assembly earlier this week and attempted to mount this today.
Since my AVF is delivered with a stock 240mm dmf i ended up getting nowhere fast as my stock starter was not suitable for use with the ECS kit. (also the crankshaft oil seal turned out to be busted as well) Did you use the stock BHW starter on your setup? Im guessing the BHW comes with a 228mm dmf as stock
Also originally there is a spacer between the tranny and engineblock on my car. I do think that will have to go when i reinstall the gearbox but i thought id ask if you are using anything inbetween? Looks to me like you are not..
Hope you can help pointing me in the right direction even if you perhaps(i guess probably) dont have first hand knowledge of my setup
Regards Espen
There is a cost summary on the first page of the thread. I spent a lot more than that summary because of trying different options and performance mods.papadelogan said:I'm almost scared to ask what this would cost.... I'd LOVE to have an A4 Quattro diesel, but the $$ to do so seems... intimidating.
I am not sure if the Passat body can just take the 4motion rear diff/subframe assembly as a bolt on or if fab mods are required. In the past (B3), the wagon version were a bolt on for syncro subframe, but the sedan had different floor pans. Sombody else on here probably knows. If it was a bolt on, you could get away with an Audi TDI triptronic from Europe, ECU, some wire mods, rear subframe with diff, axels, drive shaft and hanger bearings. Perhaps a different fuel tank and exhaust mods as well. Ask Scott Dewitt what he thinks.rspring said:What would it take to convert a B5.5 TDI to synchro/4motion? Preferably retaining an auto?
To be honest the simple answer would be to get an AWD car.rspring said:What would it take to convert a B5.5 TDI to synchro/4motion? Preferably retaining an auto?
Sigh and 18 months later I'm still trying to get caught up with paying customers... One problem working your own business, you don't get paid to fix your own stuff...Scott_DeWitt said:Yup as soon as I get caught up on the 6 speeds I've sold, I'll have a Euro spec 2000 A4 conversion I'll be writing up.
well.. it has been an amazing ride. I truley loved this car!! Was keeping everything in top shape. Had added HID's and some body molding deletes (bit of mig welding and painting to accomplish this). Unfortunately, ex wife totalled it of in a highway accident. The good news..the rad support, motor, tranny, and all the other conversion parts were untouched by the accident. The bad news..the rest of the car is not recoverable. The impact tore of the front passanger wheel before the main impact hit the A pillar and twisted the whole cab causing the windows to blow out and air bags to go off. It is sitting in storage right now. Amazingly, the pickup truck that hit it was in much worse shape and also ended up rolling several times in the ditch. The ex was unhurt in anyway other than little bits of glass all over her...so yes..A4s are VERY safe! I am contemplating selling everything as a pacakge and have a new build to replace this daily driver..perhaps posted in 4 to 6 months time. right now I am focused on work and project insane. It is a very sad circumstance..and I have yet to recieve any insurance 6 months later.
