Lug_Nut
- Joined
- Jun 20, 1998
- Location
- Sterling, Massachusetts. USA
- TDI
- idi: 1988 Bolens DGT1700H, the other oil burner: 1967 Saab Sonett II two stroke
TDI Fest 2011 Show ' Shine event information
25 August, 2011: Show entry is limited to vehicles (cars, trucks, motorcycles, boats, etc.) presently powered by a diesel engine.
Show Classes:
Three Classes are available this year. Classes are separated into Stock, Modified, and Radical levels of change from original condition. The decision to use these classifications, which are based upon degree of modification instead of by chassis generation, was made to permit non VW diesel powered vehicles to compete on an more equal basis with the more customary VW vehicle entries, to reduce the number of classification sub-categories, and to simplify judging.
15 August, 2011: A fourth, non-judged, class has been added for those that want to be eligible for the People's Choice and Longevity awards but not have the pressure of fully preparing the car for the judged portion. Just specify when you arrive at the show registration tent that you wish for a non-judged entry form.
Class selection:
The Exhibitor will choose the one class in which he or she wishes for their entry vehicle to compete when registering at the show area on the day of the show. This class choice is up to the entrant to decide. It is not for the judges or registration personnel to classify a vehicle. Any car could be entered in any of the three classes, but it will be judged to the criteria, and using the score sheet, of the class the exhibitor will have selected upon entry to the show arena.
An exhibitor may think that the modifications they have made are minor, would be at most a minimal deduction, and that they would do better overall if entered and competing in a 'stock' class, than if competing against the entries in the 'modified' class.
Or they may think that their class ranked score of their lightly modified car would be better if it were to be entered in the 'modified' class than if it were entered in the 'stock' class.
Or that the quality and execution of their less extensive modifications are enough to counter a more highly changed, but less well done, entry in the 'radical' class.
The entrant will need to consider in advance which class he or she thinks their entry vehicle will be a better competitor based on the guide or examples suggested in the Class Descriptions below.
Class descriptions:
Stock: As delivered new from the dealer, or as could have been delivered new from the original dealer. Only equipment, options and accessories offered through the manufacturer or original dealer for that vehicle in the year of the car’s manufacture are considered to be ‘stock’.
For example: A4 handbrake cup holders should be on a late A4 and would a deduction if not present, but would not be original to an early A4 and would be a deduction if they were installed.
Modified: Exchanges, upgrades or retrofitting of non-original items into the vehicle.
For example: other manufacturer's stereo systems, aftermarket wheels, added tint on windows, front mount intercoolers.
or installation of items intended for other model cars into the vehicle.
For example:
Exchanges between models: installing GTI seats in a TDI, or Jolf or Getta nose swaps.
Exchanges between brands: Audi wheels on a VW.
Exchanges between markets: Euro code lights on US cars or Euro badges.
Radical: much more extreme in scope than Modified, more than mere bolt on or swapping of like for like components, requiring engineering and fabrication of items.
For example:
Suicide doors, AWD installations, TDI Eos, or a gull-wing SL Mercedes with CDI engine swap.
Ranking for Recognition Awards
Each of the three classes is being judged to a different standard. To maintain equality between classes, the points earned by an entry in each class will be converted to a percent of that class's leader's score.
For example:
If the entry with the highest judged score points in the 'Stock' class earned 50 points, and another entry in that same class earned 45 points, that second entry earned 90% of that class leader's points.
If the highest judged score in the 'Radical' class were 80 points and an entry in 'Radical' earned 60 points, that is 75% of that class leader's points.
The 'Stock' entry earning 90% of the 'Stock' class leader points will be ranked higher in consideration of recognition than the 'Radical' entry earning 75% of that 'Radical' class leader's points.
Best in Show (one award):
Each of the class leading entries, as based on judged points earned, will be entered as nominees in a "run-off" to select a Best in Show. The selection of one entry from these three class leaders to earn this Best in Show award will be performed by a judge that hadn't judged any of the classes. This Best in Show selection is a non-scored selection. The selection criteria is simply: "Is this stock class nominee a better representation of 'stock', than this modified nominee is a representation of 'modified', or this radical nominee is a representation of 'radical'? The one entry selected from these three nominees will earn the recognition of “Best in Show”.
August 25 2011: Note that this Best in Show judging is an additional judging that will take place after all the cars are judged for class ranking. The top scoring vehicle in each of the three judged classes must be present for the three way run-off judging for best in show.
If a top score in class vehicle is not present at the time of the Best in Show judging, the selection for Best in Show will be from the remaining class leaders present. The missing vehicle(s) will still earn the best in class award for their class, but will not be eligible for the Best in Show.
Should none of the three class leader vehicles not be present for the Best in Show judging, the highest Longevity score of those three class leaders will be used to select the Best in Show recipient.
Best in Class (two awards):
The two remaining nominees in the run-off will each be declared “Best in Class” in recognition of earning the most points of all the entries in their chosen class.
Top Ten (seven awards):
The next seven highest percentage earning entries, regardless of class, will receive recognition for scoring well against their class leader. These recognition awards are based on the percentage of points an entry earned relative to that class's leader’s judged points. Doing well and being tougher competition for a class leader will gain recognition. Being a more distant second to the class leader in a class size of two entries isn't enough for recognition this year.
People's Choice (one award):
One selection, un-judged, un-pointed, based on a popular vote ballot, will be chosen.
Longevity (one award):
One show vehicle will receive recognition as a hard use survivor. The selection of the entry earning this recognition is based on a show vehicle's information and application of a formula to that data.
The right to revise this information between now and the actual day of the show is reserved, but I don’t expect there will be any significant changes. Official information will be available at the show registration area on the morning of the show.
Lug_Nut
3 August, 2011
Update: 15 August, 2011: I've created a non-judged category to allow those that would prefer to not 'compete' for the judged points and those ten recognition award that the judges will be deciding, yet still wish to be entered for the voting for the "People's Choice" award and for the longevity award.
This declaration of "stock", "modified", "radical", or this newly added 'not judged' classification, needs to be made when the vehicle is entered.
Due to scoring tabulation requirements it will not be possible to change the classification later, so consider carefully before arriving to register for the show on Saturday.
Update 25 August, 2011: I've added a contingency action should one or more of the best in class vehicles not be present for the Best in Show judging. See the Best in Show section for details.
I've added an eligibility clause that the vehicle must be diesel powered. I know it's expected to be, but wasn't specified.
Show Classes:
Class selection:
Class descriptions:
For example:
For example:
For example:
Lug_Nut
3 August, 2011
