3L3M3NT
With my VNT-17/22 and the stock PD100 injectors installed on my BEW, I maxed my car out at 150 whp. Then I upgraded to PD150 injectors and had my car dynoed and made 173 whp. I'm sure there's more to be had there if one was to install a better cam and to port and polish the head.
Then, from what I understand the PD100 injectors will make slightly more power with the same set of larger nozzles (for example if Firad +80% nozzles were installed) that would be on a set of PD130/PD150 injectors.
I would stay away from the injectors that came in the MKV Golf, since those have a slightly smaller circuit for the fuel to flow in the injector. Most injectors have an 8mm circuit for the fuel to flow through versus the 7.5mm circuit on the BLS or here in the US BRM injectors have. Like you mentioned they more than likely did this for emissions reasons.
Hopefully someone more knowledgeable will correct anything I may have gotten wrong or add some additional helpful info, but I hope that points you in the right direction.
