kkberg
I can't seem to find anyone who can diagnose the problem with my TDI. When the engine is cold it starts right up, but quickly drops in RPM (coughs -almost dies but doesn't). While it is surging (only a couple of times when it isn't too cold out) it is smoking badly. If you try to drive it right away it shugs and sputters and smokes badly, especially at low RPM. If you let it sit warming up for a couple of minutes it runs pretty good, but smokes a lot worse than it used to (even with mild acceleration). After it warms up the idle is rough, but not all the time - it comes and goes. It really isn't too bad, but definately not right. I have gotten some advise, but nothing has solved the problem yet.
I have replaced the following parts:
air filter
fuel filter
vacuum hoses
timing belt
glow plugs and harness
fuel injectors
fuel temperature sensor (inside injector pump)
There is about 145,000 miles on the vehicle, any expert advise would be greatly appreciated!
Thank you.
air filter
fuel filter
vacuum hoses
timing belt
fuel injectors
Thank you.
