Well, I just put the gauges on. Bear in mind these are HF specials.
Resting pressure was off the scale on LP and at 130 on HP. Engine bay was still warm from earlier exertions so nothing too worrying there.
At idle, LP was 45-50, HP was somewhere around 300-350. Compressor was engaged continuously, even after running for a while (It has cooled down from earlier). Put some pedal down to around 2krpm and the cut in/out started to happen. Hard to get a measurement from the gauge but the HP was up near 450.
So looks like it definitely needs both fans. And without them, it hammers the compressor pretty hard, in something like a 10 second on, 10 second off cycle. That can't be good for it. I was thinking of making the fans an "every oil change" check but I think the "every fill up" suggestion is more reasonable. At the *very* least, it's something to check before you put the AC on for the first time coming out of winter.
As for the old AC, I don't have an plans to head to SC but if I hear of someone or you know someone around TN, let me know. I wonder if I could put a travel bug on it
