How to disable / disconnect DRL - with pictures
rme
Georgia
Jetta
Thanks Burningmoney....I've got two left hands that are all thumbs and I'm blind in one eye and can't see out of the other and I was able to do this mod....
graeme86
Brisbane, Australia
Not yet - fuel is too cheap! - 3.2 VR6 R32
In OFF position - push knob straight in as far as it wants to go and turn to right and it will stay locked down and recessed within the switch face. Knob should be approximately vertical in this position, but recessed down inside the face.
Then you just pull the whole switch assembly straight out (don't try turning whole switch assembly left or right)
romad
Prescott, AZ
2005 Jetta GLS Wagon "Cranberry"
I just read this entire thread and thought I'd post some interesting history. Way back in the mid 20th Century, people who wanted to be "safe" and "seen" during the daytime would wire a low wattage bulb in the center of the grill. After some years of this various "safety studies" were done and it was determined that anything less than fullpower low-beams were either NOT helpful or were a HAZARD because the lights caused problems when determining the distance/speed of the car. So several states banned these lights. Fast forward to the late 20th Century and DRLs start showing up on Saabs & Volvos. Now, because the Swedes are considered very sharp and intelligent people, their "safety studies" had determined the reverse of the previous ones so the "no low power lights" laws stopped being enforced.
Only one problem: that of determining distance and speed of an oncoming DRL-equipped vehicle remains, BUT it also exists with ANY front lights on in the daytime, be they DRL, fog, parking, or headlights. I can determine when it is safe to pass during the daylight if the oncoming vehicles do NOT have any lights on; I can't if they do have lights on. Why? Because fog/DRLs make the vehicle seem farther away than it actually is (safe to pass), while normal headlights make the vehicle seem closer than it actually is (unsafe to pass).
I wouldn't be surprised to find out that the old no-low power lights on in daytime laws are still on the books, just waiting for a cash-strapped government entity to start enforcing it as a means of "revenue enhancement". :)
romad
Prescott, AZ
Did you just put electrical tape over the TFL pin of the switch? That is all that I did and all other lighting remained functional.
Jarrod B
San Antonio, TX
2014 Passat TDI
I got new headlights for a 97 Passat.
they end up beeing euro parts, and have 3 bulbs instead of 2 on the old US headlights. I have DRL, regular headlight and high beam. But the car does not seem to be wired for this. I m not sure how far back i d need to go to get the specific wire for DRL, so i can just use the 5 watt bulb for drl.
i would like to use that 5w bulb for drl instead.
Personally I simply cut the wire on the back side of the switch when i replaced it with a euro switch and soldered (yes soldered) on a set of male / femal connectors so if i for some reason want to DRL's again i just pop the switch out and connect the wire.
Personally I know DRL's are supposed to be a safety thing but i think they are over rated and simply burn out headlights even faster. Its also rather annoying because it seems there are a lot of people with DRL's in poor driving conditions that now forget to turn on their headlights because they can see fine, problem is their tail lights are not on so you cant see them till you are on top of them.
i see this too. they rely on the drl for their lights...doh.
said room's occupant shall appreciate my modification.
hahahaha
Boatdocktor
Massachusetts
2003 JET A
W/ loose cable lift E brake just 1 notch whala no lights ! It is how you sneak home at night!!!! hey did anbody try a sw. at the e brake wire as a cut out?? the ebrake light will remind you that you are not in "lights on for safety mode"
TriviaSteve
central PA
2003 Jetta GLS Wagon, 550K miles, 2015 Golf Sportwagen TDI S, 100K miles and a 65 beetle
i wondered the same thing...
what happened to the pictures?
I wondered the same thing...
This is something I want to do to mine as well. My reason is actually for night-time driving, of which I do a lot.
To signal to trucks that they're clear to pass, I can't dim the lights due to the DRL's. Flashing high beams, IMO, has more of a tendency to temporarily blind other drivers. I'd rather be able to dim my lights for an instant, which is impossible to do because of the DRL's.
Signaling to drivers also indicates to them that you're at least somewhat coherent and not driving while impaired, be that by alcohol or sleepy or whatever.
And that, I think, is pretty safe.
A-Dub
GTA, Ontario
2009 Touareg TDI
I turned off DRL lights on my Touareg.. It is way nicer this way.. At least i am the boss: i decide when they need to be turned on or needed, rather than being treated like a robot by Canadian Transportation Authority and have it on all the time...
Jarrod B
San Antonio, TX
2014 Passat TDI
I did that on my 06 Jetta when we were in a Christmas drive through park. By the end of the trail, I smelled rear brakes bad lol.
Powder Hound
2003 NB: TFL pin does nothing.
Pulling the 173 relay did not turn off DRLs but did lose the e-brake warning light.
Taping pin B in the switch worked. Pulling the B pin wire off the female plug on the back of the switch would also have worked, but I don't have a release tool for the female jr. timer pin part.
Rustydog
Palm Desert, Ca
2014 JSW TDI
Anyone do this for a mk6 Jetta tdi?
Bump on this.
I must be missing something on my 2014 JSW TDI; is there no way to sit with accessories on and not have my DRL's on?
ar2013tdi
Maine
2014 Sportwagen DSG
Bump on this.
Applying the emergency brake will turn them off.
Drunken_Unicorn
Idaho
'05 Jetta Wagon
Hey can someone post a picture of what pin needs to be taped on the switch? Links to the pictures are broke.
TdiRN
FL
2002 VW Jetta, 5 speed, 400k milesish
I bent the little tab down and yes my DRL are disabled but now when I lock the car the horn doesn't honk. Could I have lost anything else by doing this?
austintg
Texas
2016 Audi A6 Technik
Did you double check to see the setting wasn't changed? That's just a simple option that you can turn off and on yourself. I've always turned mine off on my TDi's.
Austin
TdiRN
FL
Austin
I'm an idiot my hood wasn't latched all the way.
austintg
Texas
Well at least you figured it out. It's nice when there is a definite explanation for what's going on no matter how palm-face it might be.
Also I am just so freaking happy I stumbled on this thread. I've been searching for ways to disable my DRL's on my 10 Jetta and finally found it. How do y'all figure this stuff out??
Austin
Mike Morriss
Ponca City, Oklahoma
99 New Beetle, 91 Vanagon TDI conversion, 05 New Beetle, 2014 Jetta Sportwagen
Another option -
I have an 05 Beetle that was made in Mexico. I tried to do the mod where one puts plastic in the TFL slot in the headlight switch connector. The TFL slot had no wire/connector in it. I saw somewhere someone else had a beetle made in Mexico. That person couldn’t use the TFL slot either and had used the B slot instead. I put the plastic in the B slot today and then tested all positions of the headlight switch. It looks like that did the trick. All lights off with the switch in the off position. All other positions work as expected.
leftyserve
Lexington, SC
Stock 2003 Jetta TDI Wagon. Turned in my 2012 Jetta TDI Sportwagen on 2/3/17. Hated to see it go!
Simple!
Did it, even without the photos! I bent my TFL pin down, and it worked like a charm. I too am tired of replacing headlight bulbs!
Tyler22474
West Central Wisconsin
'06 Jetta 1.9l Automatic DSG
From what I've seen, the switches are relatively cheap. (Under $20) You would just have to make sure to get the right one for your specific car. I tried this mod on my MKV Jetta 1.9l without fog lights and it disabled the DRL's, but also acted like the switch was on, so I couldn't turn off the low beams. Any fixes for this? I tried bending the middle pin, but it was a bit of a pain to get back up. I had to use a tweazers to pull the pin back up, fixing the switch, but turning the DRL's back on. Fixes?
romad
Prescott, AZ
Those $20 "Euro" switches are usually Red Chinese crapola.
I just put a piece of electrical tape over the pin on my non-Red China Euro Switch - worked just fine.
