I've got an 06 Jetta PD BRM code engine with a cracked #4 cylinder. The cam is done too. I've owned and worked on many VW/Audi products over the years and still own an 83 Rabbit Pickup (used to be a Diesel...).
I would really appreciate suggestions for sources of replacement block and cam along with preferred suppliers of gaskets and hoses. The turbo was replaced about 5k ago along with the timing belt so that stuff should be good to go.
I'd like to put in an aftermarket cam since I'll be right there but if I'm not upgrading the turbo does that make sense? Should I chip it at the same time? Other upgrades?
The car is a DSG so obviously I can't build this thing to 200hp but I'd like to improve the grunt a bit. The car is the wife's daily driver so huge changes might result in excessive couch time...
