Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi A3
Audi A3 Discussions area for Audi A3 TDI (2010+ in Canada & the US).
Old May 11th, 2020, 17:10   #1
11tdia3
Default 2011 A3 Fob reprogram
any idea how to get my keys to lock and unlock doors, I reset oil with scanner now this happened, not sure what I did
11tdia3 is offline   Reply With Quote
Old May 12th, 2020, 09:45   #2
tjg
Just use the key normally (driving the vehicle) and it should reprogram on its own after a bit.
You might need to lock/unlock the doors manually a few times as well.
tjg is offline   Reply With Quote
Old May 12th, 2020, 13:04   #3
11tdia3
Ok, Ill give it a try, has this worked for you?
Old May 12th, 2020, 13:10   #4
tjg
in the context of either my Audis or VWs needing the keys to be "reprogrammed" when I take the battery out for services, yes.
I'm assuming your windows are not currently one touch-up/down as well?
Old May 12th, 2020, 13:31   #5
11tdia3
Yeah, I dont believe they are working now that you mention this.
Possible to reprogram Key Fob from different car? jpg98 VW Passat Family (NMS and B7) TDIs (2012+) 9 January 12th, 2020 17:23
Key Fob Reprogram? cmeller VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 June 5th, 2015 09:01
Key fob reprogram aslspiderman VW MKIV-A4 TDIs (VE and PD) 0 September 29th, 2013 17:18
how to reprogram my key fob weeredjetta TDI 101 5 March 29th, 2012 20:49
Key Fob reprogram Nash_TDI TDI 101 4 March 22nd, 2005 13:21
Page generated in 0.13896 seconds with 11 queries
[Output: 65.47 Kb. compressed to 57.91 Kb. by saving 7.56 Kb. (11.54%)]
