Old May 6th, 2020, 14:36   #1
Dangelo64125
Default Hiccups or rpm drops
I have a 2015 vw Passat tdi. Might be obvious since Im in the tdi forums. So the issue I have been experiencing is while driving might call it a hiccup or even a stutter. I notice the rpms jump or drop a bit. Its almost like a stutter step. I have changed the fuel filter, oil change, and replaced the air filter. I do not know what would cause this. Has anyone experienced this or know what it might be? I would rather not take it to the dealer and pay $125 for a diagnostics fee if its only a $12 relay or something like that. Any help is appreciated.
Dangelo64125 is offline   Reply With Quote
Old May 7th, 2020, 16:00   #2
MB2VW
You need to run a VCDS scan.
One of my fleet cars (15 passat tdi SE) has had a similar one time event. The VCDS stored this:
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 D HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9466
Revision: 8AH20---
Coding: 011D0012032410080000
Shop #: WSC 05029 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016D 004002
ROD: EV_ECM20TDI01104L997016.rod
VCID: 3467582A9F8DC326D6-8060
1 Fault Found:
23010 - Exhaust Gas Recirculation System
P240F 00 [104] - Response too Slow
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 6
Mileage: 79243 km
Date: 2020.04.17
Time: 00:20:26
Engine speed: 2339.00 /min
Normed load value: 70.2 %
Vehicle speed: 137 km/h
Coolant temperature: 90 C
Intake air temperature: 130 C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.260 V
Unlearning counter according OBD: 35
Air mass dynamic during negative increase: error criterion: 0.27 kg/h
Air mass dynamic during positive increase: error criterion: 4.54 kg/h
Air mass dynamic during negative increase: error threshold: 9.00 kg/h
Air mass dynamic during positive increase: error threshold: 4.00 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 52.73 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.06 %
Readiness: 0 1 0 0 0
For what it's worth...
MB2VW- (Mark Z.) 2016 Passat SEL 1.8 TSI
2015 Passat SEL TDI, Silver
Biz Fleet - Two 2015 Passats SE(L), Two 2015 GSW SE
RIP:2012 Passat TDI SE (Buyback), 2000 Jetta TDI GXL
MB2VW is offline   Reply With Quote
Old May 7th, 2020, 18:01   #3
Dangelo64125
Where can I get a VCDS scan performed at?
hiccups FVWVWF VW MKVI-A6 Jetta Sedan (~ 2011+) 11 July 23rd, 2016 11:44
Hiccups Max12 TDI 101 12 November 4th, 2013 10:10
Power drops off at about 2600 RPM kulwap TDI 101 7 July 27th, 2009 11:11
MAF drops like a rock after 2700 rpm claytski VW MKIII-A3/B4 TDIs 1 December 28th, 2007 13:33
Torque drops @ 2200 rpm Jasper23 TDI Power Enhancements 0 May 1st, 2001 07:59
Page generated in 0.13119 seconds with 11 queries
[Output: 58.82 Kb. compressed to 53.60 Kb. by saving 5.22 Kb. (8.88%)]
