Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old August 28th, 2015, 14:56   #1
Luv My 02 TDI
Fuel Economy: 52/48/44
Default 2015 Jetta TDI SE Power ACC and Constant
Well I added a front and rear dash cam (LUKAS LK-9750) to my Jetta the other day. I figured I would post the power slots I am using in the event that some else needs a Constant and Switched Power source.
My dash cam has tow power leads.
1. Yellow Wire to connect to a Constant 12v Power Source.
2. Red Wire to connect to a Switched Power Source.
3. Black Wire for Ground.
The reasons for the two power sources is so the the Dash Cam can be switched to turn on with the ignition or always have power so the camera can record when the vehicle is parked.
I found Slot 26 is a switched slot and is the 2nd from the end on the right side, between the 1 and 10 amp fuses. On the fuse guide I found it is listed as Brake system vacuum pump -V192-
I found Slot 49 has Constant power is on the top row 7th fuse from the right side between a 20 and 30 amp fuse. On the fuse guide I found it is listed as Climatronic control unit -J255- A/C control module -J301-
I hope someone finds this information useful.
2015 Jetta SE TDI | 2010 Jetta TDI sedan White Gold Metalic / Titanum Black W/ underseat drawers and Dash cubby | 2002 Jetta TDI//1999 NB TDI SOLD ***Before you post ANYTHING .. CLICK HERE !!!***
Luv My 02 TDI is offline   Reply With Quote
Old August 28th, 2015, 14:58   #2
steve1479
You are a gentleman and a scholar, been looking for something like this for a while. Much thanks!
steve1479 is offline   Reply With Quote
2015 TDI Jetta SE Connectivity: Rims and Tires Samyourman Private TDI Items for Sale/Wanted 1 April 30th, 2015 19:07
New 2015 Jetta TDI SE w/Connectivity CODE4LS1 VW MKVI-A6 Jetta Sedan (~ 2011+) 4 February 15th, 2015 10:03
Thinking of buying 2015 Jetta TDI SE oceanrunner VW MKVI-A6 Jetta Sedan (~ 2011+) 19 February 14th, 2015 06:33
2015 Jetta TDI SE auto headlight conversion B0ssanova VW Passat Family (NMS and B7) TDIs (2012+) 4 December 25th, 2014 18:24
Purchasing 2015 Jetta TDI SE Tomorrow Motorbreath VW MKVI-A6 Jetta Sedan (~ 2011+) 14 November 25th, 2014 05:00
Page generated in 0.13154 seconds with 11 queries
[Output: 53.69 Kb. compressed to 49.71 Kb. by saving 3.98 Kb. (7.41%)]
