Old September 19th, 2006, 06:18   #1
torifile
Default 20,000 mile service - checklist
I'm coming up on my 20,000 mile service and I want to make sure I don't miss anything. I've watched the fuel filter replacement video (and I'm a little worried about doing it right) and I know how to change my oil. What else do I need to do? Any gotchas or caveats when changing the fuel filter? A while back, I changed my oil for the first time and it went fine, so I'm hopeful I won't screw it up.
torifile is offline   Reply With Quote
Old September 19th, 2006, 06:43   #2
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Change the cabin air filter.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old September 19th, 2006, 06:44   #3
torifile
Thanks. I did that about 2,000 miles ago. It was a little smelly.
Old September 19th, 2006, 06:51   #4
jasonTDI
jasonTDI's Avatar
The smell is in the AC evaporator actually. You need to use some product designed to kill mildew/mold to get rid of that or sometimes some Lysol sprayed into the blower from outside after removing the filter. Flood it, run around and hit the recirc button and let it circulate on high for 10 minutes.
Old September 19th, 2006, 06:53   #5
torifile
I guess I should have posted here to find out what to do. I just searched and everything said to replace the filter. Oh well, the smell's mostly gone. I'll lysol it when I do the maintenence next week.
Old September 20th, 2006, 15:23   #6
2004STARWARSTDI
2004STARWARSTDI's Avatar
Arrow Fuel filter
Read about trick for removing filter is to push down on filter and turn. It will then pop up and easy to remove.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2020
A4 Limp Mode,A4 tech.com/index.php/Category:Fault_Codes"]Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old October 18th, 2006, 08:06   #7
torifile
Well, I got my fuel filter replaced and I also did my air filter since I was ordering stuff from tdiclub (I don't know if the air filter was due - according to my dealership it was). I was able to do both of them without incident and saved myself at least $70. The dealer wanted $100 to replace the fuel filter. It cost me $28 and 10 minutes.
One thing, though: I didn't realize that the fuel filter didn't come with the washers (the blue and black ones on the T hose) so I didn't put new ones on. Is that a problem? I can't believe that the filter didn't come with them because the Mann Oil filter I ordered did. Did I just lose them in the box or something?
Old October 18th, 2006, 08:17   #8
torifile
There's a reason I'm not working in a field where attention to detail is all important. The washers were in the box. I just put them on. I think my first real maintenance other than a simple oil change was a success. I couldn't have done it without studying that MoGolf video 4 times, but I did it none-the-less.
Old October 18th, 2006, 08:20   #9
basskleff
basskleff's Avatar
Fuel Economy: 40-43 overall
I did my filters about 3 months and 5K miles ago.
I recall that the Mann fuel filter I got from dieselgeek.com had the replacement O-rings.
From experience with other vehicles, bikes, etc, IMHO, if the originals aren't cracked or especially worn, you won't have a problem reusing them.
Was it a Mann filter? They were pretty small so they could be tucked under a flap or have fallen out.
basskleff is offline   Reply With Quote
Old October 18th, 2006, 08:31   #10
torifile
Yeah. They were in the shipping box. They must have fallen out when I took the filter out to look at it. I replaced them just to be safe.
Old October 18th, 2006, 11:18   #11
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
Just make sure you are using the recommended (really more like required) engine oil for your car. Will go a long way toward ensuring long term happiness.
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old October 18th, 2006, 11:26   #12
dieseldorf
top post dawg
dieseldorf's Avatar
Tori, how about this? Print several copies of this VWUSA list, check off the jobs as completed and maintain these records in your vehicle file.
http://www.vw.com/spweb/pages/spweb/...00&units=MILES
Old October 18th, 2006, 12:41   #13
torifile
Will do both of those recommendations. Normally, I'd change the oil myself, but the VW service people didn't do their check-in inspection as promised, so they had to pay up with a free oil change. I made sure to tell them that I knew exactly what type of oil they should use (505.01) and I expect them to use it. Of course, the mechanic said my next oil change is due in 5k miles which made me worried that he didn't use the 505.01 but they're just money grubbing bastards there. Looks like I didn't need to change my air filter this time even though they said it was due. I hate that dealership.
Old October 18th, 2006, 13:03   #14
dieseldorf
top post dawg
dieseldorf's Avatar
LOL. We all learn sooner or later
Old October 18th, 2006, 20:01   #15
Zero10
Zero10's Avatar
Is there a set of instructions for changing the cabin air filter somewhere for people like me?
I'm at 32,200km and just waiting for my filter kit to show up....
87 Porsche 951
05 Golf GLS TDI
Zero10 is offline   Reply With Quote
Page generated in 0.15581 seconds with 10 queries
[Output: 120.58 Kb. compressed to 99.78 Kb. by saving 20.80 Kb. (17.25%)]
